 Post subject: Toshiba 3 TB Ext. head Problem
PostPosted: February 15th, 2019, 16:55
Hi there.
Hdd fall down aprx. 40cm and not booting. When i plug it disk was beeping 4 times(head sound) and stopping spin. I searched and i watched some videos. They were telling "maybe head stacked".
Lost is lost and i decide to open hdd case.
Really head was stack between disks. Somehow i released the head( too kindly) and pluged the HDD.
However head is always making the same movement but not booting/starting.
Windows can recognize usb ext. mass storege but not listing on disk management.
On the other hand, i canceled usb board from disk and pluged it directly to motherboard no response again.
Here is the video
https://mega.nz/#!RTAHDY7T!pDPnBsCZP73m ... 7mJdblIMTw
Thank you for your helps
 Post subject: Re: Toshiba 3 TB Ext. head Problem
PostPosted: February 16th, 2019, 5:01
What is the question??
PostPosted: February 16th, 2019, 5:33
@nurduu
This is a perfect guide, if your plan was to destroy drive and data.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: February 16th, 2019, 10:24
Done is done,if you have any answer please write.
Question is "why head is not working normal?"
Please watch the video
PostPosted: February 17th, 2019, 13:40
according to you you post, now
LOST IS LOST , DONE IS DONE.
so poroblem has solved.
Answer is -
now you have destroyed heads. also maybe platter. if you have any important data, send the hdd to DR eng.
however LOST IS LOST. DONE IS DONE
Users browsing this forum: Google [Bot] and 262 guests
