 Post subject: Palmer USB to SATA Cap Removal
PostPosted: February 15th, 2019, 15:39
Can someone confirm the caps to remove to convert the Palmer 800069 board to SATA please.
 Post subject: Re: Palmer USB to SATA Cap Removal
PostPosted: February 15th, 2019, 18:02
Yes, they look right to me.
PostPosted: February 15th, 2019, 18:24
Many thanks
PostPosted: February 17th, 2019, 13:06
Well,
The CAPSAre Correct s You Figured Them Out ,But By Converting To SATA The Only Benefit Would Be Better Control Over Drive ,You Cannot Read FW Or Make a Head MAP ,But Head Replacement Works Fine In These Models
PostPosted: February 17th, 2019, 13:42
Amarbir[CDR-Labs] wrote:
Well,
You are of course correct Amarbir, after a head swap I always prefer SATA to USB. Although the control you get is limited with these drives, it is a little more flexible. I also understand that some matching SATA boards are not compatible. So until we know more about this drive family, I prefer to convert the USB board.
Users browsing this forum: Google [Bot] and 306 guests
