 Post subject: Hitachi dt01aca100 busy
PostPosted: February 17th, 2019, 5:10
Hi I have this drive, its goes on ready mode, but after that a cant do anything, and dont recognize by MRT, I choose 7210DLE6 for that. any suggestion?
 Post subject: Re: Hitachi dt01aca100 busy
PostPosted: February 18th, 2019, 13:22
no one has any idea ?
PostPosted: February 19th, 2019, 18:53
Spildit wrote:
Send it out to someone with more experience with those drives ?
Try to access SA with correct utility ?
Can you read any module at all ?
Are you sure NVRam is native and correct ?
Try to access SA with correct utility ? yes but no luck
Can you read any module at all ? No
Are you sure NVRam is native and correct? Its native, but dont know of correct, can i write nvram from another same drive ?
PostPosted: February 20th, 2019, 3:53
Spildit wrote:
1 - Are you sure utility does work with your drive ? Is the SUPER ON accepted or does the drive report error/abort ? If SUPER ON is not accepted utility will not work with drive.
yes it work , just need to select 7210del6,
i don't see any super on option just tech-key
2 - Does the drive spin and doesn't click ? If the drive click maybe heads are gone.
yes spin normally and no strange sound
3 - If modules like USAG are damaged drive will require LOADER so that you can access to SA ...
this is all i can get from this drive, could you check it?
viewtopic.php?f=1&t=37935
SABackup.zip [125.73 KiB]
Downloaded 366 times
PostPosted: February 21st, 2019, 6:22
Spildit wrote:
You will need a loader ....
how to make or get loader ?
and how to use it?
PostPosted: February 21st, 2019, 12:18
What does native nvram mean?
Users browsing this forum: Google [Bot] and 35 guests
