 Post subject: WDC WD3200BEVT-00A0RT0 Mariner HELP !!!
PostPosted: February 25th, 2019, 7:39
Hello guys! I need your help with my hdd WDC WD3200BEVT-00A0RT0.
All defects lists are clean - G, P & SA. I can't restore now P-List from SS logs. WD Marvel read all modules and this modules are OK. Except 6F with crc error. When I trying to read all modules in WDR program it goes very slowly. I can't even make a physical test in WDMarvel because hdd freezing with DRQ error.
How can I restore P-list? What can I do for restoring my hdd?
HELP!!!
Thank's for advance!
 Post subject: Re: WDC WD3200BEVT-00A0RT0 Mariner HELP !!!
PostPosted: February 26th, 2019, 9:01
do you have full module backup?
and 6f is normal.
PostPosted: February 26th, 2019, 9:49
Yes, I have backup with all modules
PostPosted: February 26th, 2019, 9:58
Now I would like to run SelfScan for SS log restoring. I can read now 28 module from SA. There is 8 tests - B2 B2 D8 2900 DC D2 D6 D7. Need I edit the scrip file or simply run SS as is ? I have full 28 module for Mariner but there is 42 tests. Maybe it's necessary to make a script file with some tests from this module & execute them? Sorry for my english ))) Thanks!
PostPosted: February 26th, 2019, 10:01
PostPosted: February 26th, 2019, 11:29
selfscan?
do you want get recovered data or refurbish?
PostPosted: February 26th, 2019, 12:18
Refurbish only
PostPosted: February 26th, 2019, 13:17
Use auto arco and give module to another ok hard disk
PostPosted: February 26th, 2019, 14:02
Can I do this in WDR? I do not have WDMarvel full version. Only demo.
Users browsing this forum: Majestic-12 [Bot] and 85 guests
