 Post subject: Seagate Grenada Head Adjustment For repair
PostPosted: March 4th, 2019, 20:46
Hi Every body.
Grenada/ Bacall Moose, pharaoh, moose, and many more families Head adjustment for Repair in the video.
For Data Recovery the method is same, but the commands are different.
http://www.mediafire.com/file/67l4sdkla ... nt.7z/file
after write test finish.
Reading test is in process
Kind Regards
Waqas Ali
www.sediv.net
 Post subject: Re: Seagate Grenada Head Adjustment For repair
PostPosted: March 4th, 2019, 21:06
Great sir . Well done .
Fully automatic and accurate and too much work has been put on on this .
I can see the effort behind this.
Well done once again.
PostPosted: March 4th, 2019, 23:52
Nobody in their right mind is going to run AFH adjustment test on faulty heads on a drive that needs Data Recovery.
Plus it's only going to work on SOME heads that are slow reading but still see servo. Not many drives like that come for DR
PostPosted: March 5th, 2019, 0:20
Do Seagate's helium drives still use F3 architecture? If so, then this technique may be the only option in some cases (for some shops).
I wonder if anyone who has been successful with this procedure has reverted to the original adaptives and then retested the bad head. I'm wondering whether a "touchdown" on the platter may clean a dirty head.
PostPosted: March 5th, 2019, 5:08
great work
i am intereted to buy this software.
please give me the price with training
thanks
PostPosted: March 5th, 2019, 5:47
Hi doomer sir
"Nobody in their right mind is going to run AFH adjustment test on faulty heads on a drive that needs Data Recovery.
Plus it's only going to work on SOME heads that are slow reading but still see servo. Not many drives like that come for DR"
Off course you cannot work on licking drives,
Here is the condition, you can run AFH adjust only on the drives where 1 head is stop reading, or reading extremely slow like 1 MB or less then that.
its not only AFH. in video there is DAC, AFH ,RW. some hidden area cannot b visible in the screen, because size become big.
The video is related to repairing of Drive only.
If you wana see the Real Data recovery case, i can show you the case, with a video. and it works perfect.
Many poeple of forum already done this method on there DR Cases, and get good result.
This only work on drives having 1 or 2 head week, slow speed of reading like less then 1 MB.
If some one thinking it work on clicking drive, he is a fool.
Hi fzabkar
"Do Seagate's helium drives still use F3 architecture? If so, then this technique may be the only option in some cases (for some shops).
I wonder if anyone who has been successful with this procedure has reverted to the original adaptives and then retested the bad head. I'm wondering whether a "touchdown" on the platter may clean a dirty head."
Basically i am doing this on drives below , like Grenada, bacall, muskies, muskie plus, moose, pharaoh, brinks, yarrar_5400, yarrarX, etc families,
which we get in my lab for repair.
i have not saw a seagate helium filed drive in my lab for repair hehe.
Yes many person of the forum get success with this, i have done on remote for them.
but if an un-experience person touch AFH and DAC and RW, offcouse he will damage it. because there is certain limit of adjustment, once you cross that limit, after that Heads become Dead.
i am doing this by CHS mode, and its the real result.
i am set the timeout to minimum with Command. and then do a CHS test, for repair Write/ Read CHS test to compare the performance.
Once it repaired the task will stop, if it was not repair or left any zone no-repaired, then program automatic moved to Zone cutting, and cut the faulty zones of a drive in repairing process.
in the post i have written its a Repairing purpose video.
You can use this trick in Data Recovery but only by Reading CHS and adjust, again read and adjust. in software there is section for manually editing all Adaptives.
1. DAC
2. AFH
3. RW
any once can adjust manually. in all this what section have to adjust, its a question. every drive have different parameters.
There is always a formula to adjust the AFH, DAC, RW.
Kind Regards
Waqas Ali
PostPosted: March 5th, 2019, 9:44
I'm not saying that it's impossible I'm saying it's dangerous.
A drive could MD during the procedure and kill data
PostPosted: March 5th, 2019, 10:43
hi
can i ask, who made this SOFTWARE.
is that work directly on hdd, via sata port and terminal
or is that work like pc-3000 and mrt,
integrated with hardware card.
thanks
PostPosted: March 5th, 2019, 13:47
waqas_ali766 wrote:
Hi doomer sir
Waqas Ali
i'm one of them :)
Thank you Waqas for helping me to solve my Grenada case :)
My firmware database:
PostPosted: March 5th, 2019, 14:04
Hi RAJOO
Sediv Technologies Pvt Ltd. its a Registered Company in Pakistan. i am the author of this software.
its not the same as Russian Sediv software. its my own Company name.
As you know i am the only first distributor of Sediv, and from beginning, i have this company and website, and my every things is registered with this info.
so i continues my own things with this name also.
I am the author of this software.
if have SATA Power and Data Card, different then MRT and pc3000.
it have Dongle Protection + PC hard ware + Sata Card + power + internet + location.
Normally you will not feel that it have this protections. its done in few seconds only.
Kind Regards
Waqas Ali
"can i ask, who made this SOFTWARE.
thanks"
PostPosted: March 5th, 2019, 16:03
I understand that the procedure does work. However, I would like to verify that the original problem returns when the original adaptives are restored. I'm wondering whether the read problem may be due to a dirty head, in which case heating the head may cause it to touch down on the platter, thereby cleaning it.
PostPosted: March 5th, 2019, 17:41
fzabkar, Hi
For Example you have Grenada drive with 2 heads. you fully clone its head 0 with a speed of 1230 MB/s , but when you start reading from head 1 the speed is less then 1 MB or show a lot of skip Sectors.
In that conditions you have to Adjust DAC, and don't touch AFH.
For Adjusting the Values , this is a limit , what to increase.
have 4 Sections
1. WrCur
2. WrDamp
3. WrDampDur
4. HtRng
these all 4 value's have there own means. what to increase and how many times. it depends. on the Read and Write value.
For Data Recovery just Increase it to Max value of first section .
1 by 4th value on second section
1 by 3rd value on third section
and max value to last section
this will work for Grenada drive.
Bacall need AFH adjustment, and Bacall have 12 Sections. every section have there own means.
once you have a case contact me on whats app or Skype, i will show you on team viewer
whatsapp = +971-52-8991351
skype = waqasali766@hotmail.com
Telegram = +971-52-8991351
Kind Regards
Waqas Ali
PostPosted: March 5th, 2019, 19:43
I would expect that parameters 1 - 3 would affect writing only. :-?
    1. WrCur
    2. WrDamp
    3. WrDampDur
In any case, all I'm asking is, if you revert to the original settings, does the speed revert to 1MB/s?
PostPosted: March 5th, 2019, 19:45
to the great and talented MR. WAQASALI,
great work
after to see your video about your software
i feel proud to be a PAKISTANI
You are really very talented person
i think you are the only person in the WORLD
who knows this much about SEAGATE
i think your software for seagate is betterthan MRT, PC-3000 and SEDIV,
thanks
PostPosted: March 5th, 2019, 20:02
fzabkar, "I would expect that parameters 1 - 3 would affect writing only. :-?
1. WrCur
2. WrDamp
3. WrDampDur
In any case, all I'm asking is, if you revert to the original settings, does the speed revert to 1MB/s? "
This effect Reading and writing both.
After increase if you fully cloned or half cloned, then after back to original it will become to 1 MB +- again.
Kind Regards
PostPosted: March 7th, 2019, 19:56
yes, these adjustments are pretty nice, i've been doing them for 6-8 years and it really affects success rate, plus reduces demand on parts. My method is somewhat different though...
PostPosted: March 8th, 2019, 2:08
sir
you mean you have this type of software, since 6-8 years
PostPosted: March 8th, 2019, 2:53
@RAJOO, it's not as elegant as a software solution, but you can achieve the same end by hand, using terminal commands.
http://www.hddoracle.com/viewtopic.php?f=175&t=2682
Here is a solution using a ZOC script generated by Excel:
https://www.youtube.com/watch?v=W9KbKw57GxI
I did propose this solution in 2010 ...
https://forum.hddguru.com/viewtopic.php?f=1&t=17491
PostPosted: March 8th, 2019, 11:24
fzabkar,
The Steps are ok , but he is increasing by wrong way and wrong section.
and he is doing only AFH.
Kind Regards
PostPosted: March 9th, 2019, 8:25
RAJOO wrote:
sir
completely different solution that does not take ages, thus usable for dr as well.
Users browsing this forum: Google [Bot] and 43 guests
