 Post subject: Rembrndt - LDR Required
PostPosted: March 12th, 2019, 6:23
Hello guys,
Anyone got this LDR
WD60EFRX-68L0BN1
0003001M
11 & 01
Thnx
 Post subject: Re: Rembrndt - LDR Required
PostPosted: March 12th, 2019, 11:12
Here you are:
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 10
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 2480
>ROM:
>Read ROM................................ : Ok
>ROM Data size........................... : 1024 Kb
>Flash ROM dir reading................... : Ok (Active)
>Flash ROM dir reading (Ext)............. : Ok
>Modules directory address............... : 533 335
>SA regions address...................... : by default
>Module 02 access........................ : Granted
>SA Translator loading................... : Ok
>ROM Modules:
>ROM version............................. : 03.1MG
>ROM F/W version......................... : 0003001M
>Overlay F/W version..................... : 03.1NG
>Servo F/W version....................... : 01.0L
>Heads configuration..................... : by map
>Heads number in use..................... : 10
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,3,4,5,6,7,8,9
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
Copy 0.rar [504.8 KiB]
Downloaded 368 times
PostPosted: March 13th, 2019, 3:13
Thank you northwind
appreciate it..
:beer:
Users browsing this forum: No registered users and 51 guests
