 Post subject: Toshiba serial port connector
PostPosted: March 20th, 2019, 17:52
We're missing the Toshiba serial port connector for a 3.5" IDE drive. Does anyone have the pinout of GND, TX and RX on the HD, so I can connect it manually?
Thanks.
File comment: 3
File comment: 2
File comment: 1
 Post subject: Re: Toshiba serial port connector
PostPosted: March 20th, 2019, 18:32
Is that a Toshiba or a Maxtor?
PostPosted: March 20th, 2019, 18:48
Sorry for the errors Maxtor
File comment: 1
PostPosted: March 20th, 2019, 18:57
I could be wrong here, but PC3000 does not manufacture a terminal connector for the Maxtor, so you might assume there is no Tx or Rx on these boards. You can however put the drive in safe mode using jumpers.
PostPosted: March 20th, 2019, 19:10
How to access safe mode
PostPosted: March 20th, 2019, 19:42
Bottom left horizontally. See picture.
PostPosted: March 21st, 2019, 17:49
http://files.hddguru.com/download/PC-3000%20Support/Documents/Maxtor.pdf
http://files.hddguru.com/download/PC-3000%20Support/Documents/Maxtor4Windows_ver2.pdf
PostPosted: March 21st, 2019, 17:54
Isn't that copyrighted?
PostPosted: March 21st, 2019, 18:20
ISTR that some of those old docs are available via public download from Ace Lab's own web site ...
eg http://www.acelab.ru/dep.pc/doc.pc3000dos/060713.001/Maxtor_DSP_POKER_ARDENT_ver4.pdf
http://www.google.com/search?q=site:acelab.ru+filetype:pdf+maxtor
PostPosted: March 21st, 2019, 18:26
Just had a quick check and couldn't see them. But I guess if they had them up at one time they can't complain.
PostPosted: March 21st, 2019, 18:38
They're still there ...
http://www.google.com/search?q=site:acelab.ru/dep.pc/doc.pc3000dos/+filetype:pdf
PostPosted: March 21st, 2019, 18:41
You are indeed correct. There is no direct link to them from the Ace Labs site, but if they are searchable then they are available.
PostPosted: March 22nd, 2019, 1:35
I arrived here by drilling downwards from the home page:
Technical support of old equipment:
https://www.acelab.ru/dep.pc/otherproducts.php
PostPosted: March 22nd, 2019, 12:20
Well spotted. I guess they are not concerned about the legacy stuff.
PostPosted: March 25th, 2019, 17:43
He apologized for the delay and thanked the group for responding
Users browsing this forum: Google [Bot] and 48 guests
