Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
 Post subject: WD10JMVW 11AJGS2 stopped when clone
PostPosted: March 25th, 2019, 8:21
WD10JMVW 11AJGS2 (1 tb ) usb stopped when clone.
Converted to sata for clone.
I was cloning this drive. Aproxx first % 10 part was very slow. I passed this part. Clonned high speed other % 90 . Was fast and no bad sector.
Then turned again first part. Adjusted max timeout . I Clonned some. Remained % 1.67 . Customer wants that remained parts also. He accepted extra cost.
Now MRT not recognise drive. I have all modules and ldr from original disk. .
I cannot see any modules, any data now. Drive making some clicking noise but not Iike head problem sound that I heard before.
Cannot load zone table. SA info. Head test says all 4 heads died
Could be head damage or something about modules.
For head swap
I have a donor
WD10JMVW 11AJGS1
Is it compatible
Sexy Womans from your town
 Post subject: Re: WD10JMVW 11AJGS2 stopped when clone
PostPosted: March 25th, 2019, 9:40
Patient
WD10JMVW 11AJGS2
Blue
DCM : SHKTJBN
19 April 2015
DCX : CA2JJ93GW
Malaysia
Donor
WD10JMVW 11AJGS1
black
DCM : HBKTJHK
04 February 2014
DCX : EA10J13G5
Malaysia
PostPosted: March 25th, 2019, 9:44
Banned User
Head swap should work, did you clear mod 32?
[spam removed]
PostPosted: March 25th, 2019, 13:55
I cannot see any module now.
So what is mod 32
PostPosted: March 25th, 2019, 13:59
Banned User
Module 32 is the relo list, can cause drive to respond slow ans take forever to become ready. Module 32 should be cleared before imaging.
[spam removed]
PostPosted: March 25th, 2019, 14:38
Learning . Thanks for info.
PostPosted: March 25th, 2019, 15:15
hi hdddonor
can u upload the head sound.
save the ROM and SA bypass and see what is happening.
sometimes platter 0 has a small damage and now heads are not working properly.
can u upload the PCBs pictures of both hard drives.
PostPosted: March 25th, 2019, 15:18
Banned User
Forgot to mention,
remove the heads from the patient drive and inspect under a microscope. Look for any contamination on the sliders and towards the end of the heads.
[spam removed]
PostPosted: March 25th, 2019, 15:53
How do I clear. Directly deleting all data in mode 32? Or filing 0 some parts?
PostPosted: March 25th, 2019, 15:55
Banned User
Your data recovery tool should have an option to clear module 32, should be available on pc 3000 and MRT.
[spam removed]
PostPosted: March 25th, 2019, 16:09
Dananjaya wrote:
hi hdddonor
I afraid to straching platter.
Cannot access to SA. I can try to save rom. I have backed up before cloning. Are you asking read Rom again?
I guessed a head could weak when starting to clone. But , All 4 head was slow different part in first % 10 of drive. I heard some strange noises in that part sometimes. Other % 90 clonned full speed. And No bad sector
Do you mean Usb and SATA pcb s?
Or donor and patient ? (Same pcb number as I remember)
Bye the way . This drive dropped before come to me. Customer has dropped. So It was in slow response in windows
PostPosted: March 25th, 2019, 16:16
MRT has "solve slove response " . Is that?
PostPosted: March 25th, 2019, 16:17
Banned User
Yes that is it, however you need access to SA to perform that operation.
[spam removed]
PostPosted: March 25th, 2019, 16:22
I am researching before head swap.
I don't have qualify equipment for head swap. But I did swapp more before. Some working some not.
PostPosted: March 25th, 2019, 16:24
Banned User
Have you got a microscope? Sometimes if you leave the drive on for few minutes and then try to enter the WD utility SA might get loaded.
[spam removed]
PostPosted: March 25th, 2019, 16:26
I have microscope.
I did wait 1 day . Did try again with also original USB pcb. Result same.
PostPosted: March 25th, 2019, 16:36
Banned User
Stay with the SATA, USB PCB is pointless and slow, you should not be scared to turn the drive on, data recovery is never 100%. If you was to turn on the drive and listen carefully with your ear, does it sound like its trying to read or is it always clicking?
Do you know how to load LDR and Module List to check if you can test SA?
PostPosted: March 25th, 2019, 16:40
I tried load LDR.
Sound
https://we.tl/t-VHWc3RUF21
PostPosted: March 25th, 2019, 16:44
i have never used MRT. but i think there will be a option call Service Area bypass ( SA bypass) If you have ROM backup then ok. bec. sa bypass option change the ROM.if bypass Ok and if heads are ok you can see the modules and you can correct them. after correcting you have to write original ROM.
yes. i ask paitent and donor PCB. bec. i am not sure about donor head.
i think 0 _ 10% area of platter has a damage since dropped.
PostPosted: March 25th, 2019, 16:52
I don't understand why all 4 heads gone . I am not sure about heads died.
Tried again with LDR and couldn't load mode 1. I load mode 1 from my backup. . Now shows modules list. But cannot read amy modules from disk. When try to open giving error.
Model WDC ROM MODEL Fblite
Serial wdc rom sw# xyz
Capacity 1 (0 fb)
Users browsing this forum: No registered users and 142 guests
