 Post subject: hts545050B9A300 PB4O60F
PostPosted: April 15th, 2019, 21:41
How to update firmware hard drive Hitachi hts545050B9A300 PB4OC60F, what utility and what to do please help.
 Post subject: Re: hts545050B9A300 PB4O60F
PostPosted: April 16th, 2019, 15:54
I check hdd mhdd, victoria, hitachi and programs do not work at emergence of bad sectors in different places hdd hangs, works only after reset. On the other hdd hitachi understood, and in hts545050b9a300 PB4O60F can't decide how to replace the firmware.
PostPosted: April 16th, 2019, 16:21
You cannot just “replace firmware”.
Not a firmware problem, you are wasting your time.
PostPosted: April 16th, 2019, 22:38
Clone the drive with ddrescue or HDDSuperClone.
PostPosted: April 17th, 2019, 2:27
I thought about posting that kind of suggestion, but I was guessing (maybe incorrectly) from the tone of the OP’s message that they were looking to repair the drive rather than to recover data.
 Post subject: Re: hts545050B9A300 PB4OС60F
PostPosted: April 17th, 2019, 4:05
для восстановления диска файлы не требуются. Ошибка прошивки нужна PB6OC60F
no files are required to restore the disk. Firmware error need PB6OC60F.
PostPosted: April 17th, 2019, 5:13
If you try to repair a bad sector, the disk is not detected until you restart. and so in different areas of the disk.
При попытке восстановить поврежденный сектор диск не будет обнаружен до перезагрузки. и так в разных областях диска.
Users browsing this forum: Greenman and 123 guests
