 Post subject: WD3200AVJS-63WDA0 Zone allocation table error
PostPosted: April 16th, 2019, 21:02
Hello guys.
I'm with a little problem with this old WD unit.
original PCB didn't worked. I've got a very similar drive and just swapped the PCB (this model doesn't have a ROM chip).
With this other PCB, drive doesn't ID properly, but it could read and backup almost all resources (modules, tracks and so on).
This is the Log info I've got on MRT.
How should I manage to read user sectors?
Thank you so much for your time and this beautiful forum.
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 4
Head map : .....................................: F
SA Cyl Count : .................................: 128
Serials Mark : .................................: 0x9016
Control version : ..............................: 42B1
Zone allocation table : ........................: Err
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 192 Kb
ROM version : ..................................: 58.76D
ROM generation : ...............................: 58.76D
Link table version : ...........................: 01.0F
ROM Firmware version : .........................: 00580076
ROM Modules:
Flash ROM dir reading : ........................: OK
Switched off heads : ...........................: Yes
Heads number : .................................: 0x4
Heads number in use : ..........................: 0x4
heads map : ....................................: 0,1,2,3
Backuping hard disk resources
Saving ROM
Save Path:C:\UserDataFile\WDC Marvell\Tornado 2D\20190416-213656-00580076\Data\SABackup\ROM\ROM_.bin
Save ROM: : ....................................: OK
Saving ROM module
Save the module: 0A : ..........................: OK
Save the module: 0B : ..........................: OK
Save the module: 30 : ..........................: OK
Save the module: 47 : ..........................: OK
Save the module: 0D : ..........................: OK
Save the module: 4F : ..........................: OK
Backup of ROM module completed!
Saving Module
Save Path:C:\UserDataFile\WDC Marvell\Tornado 2D\20190416-213656-00580076\Data\SABackup\Modules\
Save the module:0001 ByID : ....................: OK
Save the module:0035 ByID : ....................: OK
Save the module:006D ByID : ....................: OK
Save the module:0110 ByID : ....................: OK
Save the module:0102 ByID : ....................: OK
Save the module:0103 ByID : ....................: OK
Save the module:0104 ByID : ....................: OK
Save the module:0105 ByID : ....................: OK
Save the module:0107 ByID : ....................: OK
Save the module:0106 ByID : ....................: OK
Save the module:0108 ByID : ....................: OK
Save the module:0002 ByID : ....................: OK
Save the module:0017 ByID : ....................: OK
Save the module:001B ByID : ....................: OK
Save the module:001C ByID : ....................: OK
Save the module:0014 ByID : ....................: OK
Save the module:0015 ByID : ....................: OK
Save the module:001E ByID : ....................: OK
Save the module:002F ByID : ....................: OK
Save the module:002A ByID : ....................: OK
Save the module:0021 ByID : ....................: OK
Save the module:0022 ByID : ....................: OK
Save the module:0023 ByID : ....................: OK
Save the module:0024 ByID : ....................: OK
Save the module:0011 ByID : ....................: OK
Save the module:0019 ByID : ....................: OK
Save the module:0012 ByID : ....................: OK
Save the module:0050 ByID : ....................: OK
Save the module:0051 ByID : ....................: OK
Save the module:0052 ByID : ....................: OK
Save the module:0053 ByID : ....................: OK
Save the module:0109 ByID : ....................: OK
Save the module:0061 ByID : ....................: OK
Save the module:0062 ByID : ....................: OK
Save the module:001F ByID : ....................: OK
Save the module:006E ByID : ....................: OK
Save the module:006C ByID : ....................: OK
Save the module:006F ByID : ....................: OK
Save the module:0119 ByID : ....................: OK
Save the module:1101 ByID : ....................: OK
Save the module:0033 ByID : ....................: OK
Save the module:0031 ByID : ....................: OK
Save the module:000C ByID : ....................: OK
Save the module:0034 ByID : ....................: OK
Save the module:0032 ByID : ....................: OK
Save the module:0036 ByID : ....................: OK
Save the module:0029 ByID : ....................: OK
Save the module:0040 ByID : ....................: OK
Save the module:0041 ByID : ....................: OK
Save the module:0042 ByID : ....................: OK
Save the module:0043 ByID : ....................: OK
Save the module:004E ByID : ....................: OK
Save the module:0049 ByID : ....................: OK
Save the module:004A ByID : ....................: OK
Save the module:004D ByID : ....................: OK
Save the module:0003 ByID : ....................: OK
Save the module:0004 ByID : ....................: OK
Save the module:0025 ByID : ....................: OK
Save the module:0026 ByID : ....................: OK
Save the module:0038 ByID : ....................: OK
Save the module:0039 ByID : ....................: OK
Save the module:0037 ByID : ....................: OK
Save the module:002D ByID : ....................: OK
Save the module:002E ByID : ....................: OK
Save the module:0068 ByID : ....................: OK
Save the module:0069 ByID : ....................: OK
Save the module:006A ByID : ....................: OK
Save the module:00B5 ByID : ....................: OK
Save the module:006B ByID : ....................: OK
Save the module:003A ByID : ....................: OK
Save the module:0028 ByID : ....................: OK
Save the module:003B ByID : ....................: OK
Save the module:003C ByID : ....................: OK
Save the module:003D ByID : ....................: OK
Save the module:003E ByID : ....................: OK
Save the module:003F ByID : ....................: OK
Save the module:00DE ByID : ....................: OK
Save the module:00B6 ByID : ....................: OK
Save the module:00D5 ByID : ....................: OK
Save the module:3404 ByID : ....................: OK
Save the module:00D1 ByID : ....................: OK
Save the module:00DA ByID : ....................: OK
Save the module:00DB ByID : ....................: OK
Save the module:00DF ByID : ....................: OK
Save the module:00DD ByID : ....................: OK
Save the module:00D6 ByID : ....................: OK
Save the module:3402 ByID : ....................: OK
Save the module:00D7 ByID : ....................: OK
Save the module:00D2 ByID : ....................: OK
Save the module:3300 ByID : ....................: OK
Save the module:3301 ByID : ....................: OK
Save the module:00BB ByID : ....................: OK
Save the module:3405 ByID : ....................: OK
Save the module:00D9 ByID : ....................: OK
Save the module:00D4 ByID : ....................: OK
Save the module:00DC ByID : ....................: OK
Save the module:00D0 ByID : ....................: OK
Save the module:00D3 ByID : ....................: OK
Save the module:00F7 ByID : ....................: OK
Save the module:00BA ByID : ....................: OK
Save the module:00B9 ByID : ....................: OK
Save the module:00BC ByID : ....................: OK
Save the module:00D8 ByID : ....................: OK
Save the module:00BD ByID : ....................: OK
Save the module:00BE ByID : ....................: OK
Save the module:3400 ByID : ....................: OK
Save the module:3401 ByID : ....................: OK
Save the module:00B8 ByID : ....................: OK
Save the module:00BF ByID : ....................: OK
Save the module:00E2 ByID : ....................: OK
Save the module:00E3 ByID : ....................: OK
Save the module:00EA ByID : ....................: OK
Save the module:00EB ByID : ....................: OK
Save the module:00E0 ByID : ....................: OK
Save the module:00E1 ByID : ....................: OK
Save the module:00E8 ByID : ....................: OK
Save the module:00E9 ByID : ....................: OK
Save the module:00E6 ByID : ....................: OK
Save the module:00E7 ByID : ....................: OK
Save the module:00B7 ByID : ....................: OK
Save the module:00FA ByID : ....................: OK
Save the module:00FB ByID : ....................: OK
Save the module:00FC ByID : ....................: OK
Save the module:00FD ByID : ....................: OK
Save the module:00FE ByID : ....................: OK
Save the module:00EE ByID : ....................: OK
Save the module:3E00 ByID : ....................: OK
Save the module:3801 ByID : ....................: OK
Save the module:00C4 ByID : ....................: OK
Save the module:00A2 ByID : ....................: OK
Save the module:00C5 ByID : ....................: OK
Save the module:00C3 ByID : ....................: OK
Save the module:00C8 ByID : ....................: OK
Save the module:0091 ByID : ....................: OK
Save the module:00CC ByID : ....................: OK
Save the module:00CA ByID : ....................: OK
Save the module:0099 ByID : ....................: OK
Save the module:0098 ByID : ....................: OK
Save the module:00CB ByID : ....................: OK
Save the module:00CD ByID : ....................: OK
Save the module:00CF ByID : ....................: OK
Save the module:00CE ByID : ....................: OK
Save the module:0093 ByID : ....................: OK
Save the module:00C1 ByID : ....................: OK
Save the module:00C2 ByID : ....................: OK
Save the module:00C7 ByID : ....................: OK
Save the module:009E ByID : ....................: OK
Save the module:00C6 ByID : ....................: OK
Save the module:00C9 ByID : ....................: OK
Save the module:0094 ByID : ....................: OK
Save the module:0096 ByID : ....................: OK
Save the module:0097 ByID : ....................: OK
Save the module:00A5 ByID : ....................: OK
Save the module:0092 ByID : ....................: OK
Save the module:00A0 ByID : ....................: OK
Save the module:00A1 ByID : ....................: OK
Save the module:009A ByID : ....................: OK
Save the module:009C ByID : ....................: OK
Save the module:2000 ByID : ....................: OK
Save the module:2001 ByID : ....................: OK
Save the module:2002 ByID : ....................: OK
Save the module:2003 ByID : ....................: OK
Save the module:2004 ByID : ....................: OK
Save the module:2005 ByID : ....................: OK
Save the module:2006 ByID : ....................: OK
Save the module:2007 ByID : ....................: OK
Save the module:2020 ByID : ....................: OK
Save the module:2021 ByID : ....................: OK
Save the module:2022 ByID : ....................: OK
Save the module:2023 ByID : ....................: OK
Save the module:2024 ByID : ....................: OK
Save the module:2025 ByID : ....................: OK
Save the module:2026 ByID : ....................: OK
Save the module:2027 ByID : ....................: OK
Save the module:2030 ByID : ....................: OK
Save the module:2031 ByID : ....................: OK
Save the module:2032 ByID : ....................: OK
Save the module:2033 ByID : ....................: OK
Save the module:2034 ByID : ....................: OK
Save the module:2035 ByID : ....................: OK
Save the module:2036 ByID : ....................: OK
Save the module:2037 ByID : ....................: OK
Save the module:2010 ByID : ....................: OK
Save the module:2011 ByID : ....................: OK
Save the module:2012 ByID : ....................: OK
Save the module:2013 ByID : ....................: OK
Save the module:2014 ByID : ....................: OK
Save the module:2015 ByID : ....................: OK
Save the module:2016 ByID : ....................: OK
Save the module:2017 ByID : ....................: OK
Save the module:2040 ByID : ....................: OK
Save the module:2041 ByID : ....................: OK
Save the module:2042 ByID : ....................: OK
Save the module:2043 ByID : ....................: OK
Save the module:2044 ByID : ....................: OK
Save the module:2045 ByID : ....................: OK
Save the module:2046 ByID : ....................: OK
Save the module:2047 ByID : ....................: OK
Save the module:2050 ByID : ....................: OK
Save the module:2051 ByID : ....................: OK
Save the module:2052 ByID : ....................: OK
Save the module:2053 ByID : ....................: OK
Save the module:2054 ByID : ....................: OK
Save the module:2055 ByID : ....................: OK
Save the module:2056 ByID : ....................: OK
Save the module:2057 ByID : ....................: OK
Save the module:2060 ByID : ....................: OK
Save the module:2061 ByID : ....................: OK
Save the module:2062 ByID : ....................: OK
Save the module:2063 ByID : ....................: OK
Save the module:2064 ByID : ....................: OK
Save the module:2065 ByID : ....................: OK
Save the module:2066 ByID : ....................: OK
Save the module:2067 ByID : ....................: OK
Save the module:1000 ByID : ....................: OK
Save the module:00B1 ByID : ....................: OK
Save the module:00B2 ByID : ....................: OK
Save the module:1001 ByID : ....................: OK
Save the module:1002 ByID : ....................: OK
Save the module:1003 ByID : ....................: OK
Save the module:1005 ByID : ....................: OK
Save the module:1004 ByID : ....................: OK
Save the module:1007 ByID : ....................: OK
Save the module:1008 ByID : ....................: OK
Save the module:8010 ByID : ....................: OK
Save the module:802C ByID : ....................: OK
Save the module:8035 ByID : ....................: OK
Save the module:8038 ByID : ....................: OK
Save the module:803C ByID : ....................: OK
Save the module:8016 ByID : ....................: OK
Save the module:801D ByID : ....................: OK
Save the module:8044 ByID : ....................: OK
Save the module:8031 ByID : ....................: OK
Save the module:8062 ByID : ....................: OK
Save the module:8063 ByID : ....................: OK
Save the module:8041 ByID : ....................: OK
Save the module:8042 ByID : ....................: OK
Save the module:800E ByID : ....................: OK
Save the module:802D ByID : ....................: OK
Save the module:8019 ByID : ....................: OK
Save the module:802F ByID : ....................: OK
Save the module:8034 ByID : ....................: OK
Save the module:802E ByID : ....................: OK
Save the module:8032 ByID : ....................: OK
Save the module:8017 ByID : ....................: OK
Save the module:8002 ByID : ....................: OK
Save the module:800B ByID : ....................: OK
Save the module:8005 ByID : ....................: OK
Save the module:8020 ByID : ....................: OK
Save the module:8046 ByID : ....................: OK
Save the module:8045 ByID : ....................: OK
Save the module:8027 ByID : ....................: OK
Save the module:8014 ByID : ....................: OK
Save the module:801C ByID : ....................: OK
Save the module:8023 ByID : ....................: OK
Save the module:801F ByID : ....................: OK
Save the module:803A ByID : ....................: OK
Save the module:803E ByID : ....................: OK
Save the module:8012 ByID : ....................: OK
Save the module:8026 ByID : ....................: OK
Save the module:802B ByID : ....................: OK
Save the module:8029 ByID : ....................: OK
Save the module:802A ByID : ....................: OK
Save the module:8037 ByID : ....................: OK
Save the module:803B ByID : ....................: OK
Save the module:800F ByID : ....................: OK
Save the module:800A ByID : ....................: OK
Save the module:8025 ByID : ....................: OK
Save the module:8009 ByID : ....................: OK
Save the module:800C ByID : ....................: OK
Save the module:8006 ByID : ....................: OK
Save the module:8018 ByID : ....................: OK
Save the module:800D ByID : ....................: OK
Save the module:8008 ByID : ....................: OK
Save the module:8024 ByID : ....................: OK
Save the module:8015 ByID : ....................: OK
Save the module:8007 ByID : ....................: OK
Save the module:8065 ByID : ....................: OK
Save the module:801A ByID : ....................: OK
Save the module:8030 ByID : ....................: OK
Save the module:801E ByID : ....................: OK
Save the module:8001 ByID : ....................: OK
Save the module:8022 ByID : ....................: OK
Save the module:8064 ByID : ....................: OK
Save the module:8049 ByID : ....................: OK
Save the module:805D ByID : ....................: OK
Save the module:805E ByID : ....................: OK
Save the module:805F ByID : ....................: OK
Save the module:8060 ByID : ....................: OK
Save the module:8061 ByID : ....................: OK
Save the module:8011 ByID : ....................: OK
Save the module:803F ByID : ....................: OK
Save the module:8040 ByID : ....................: OK
Save the module:8033 ByID : ....................: OK
Save the module:8043 ByID : ....................: OK
Save the module:8000 ByID : ....................: OK
Save the module:8021 ByID : ....................: OK
Save the module:8FFC ByID : ....................: OK
Save the module:8FFD ByID : ....................: OK
Save the module:8FFE ByID : ....................: OK
Save the module:8047 ByID : ....................: OK
Save the module:8048 ByID : ....................: OK
Save the module:8004 ByID : ....................: OK
Save the module:8003 ByID : ....................: OK
Save the module:8028 ByID : ....................: OK
Save the module:8039 ByID : ....................: OK
Save the module:803D ByID : ....................: OK
Save the module:8036 ByID : ....................: OK
Save the module:801B ByID : ....................: OK
Save the module:8013 ByID : ....................: OK
Save the module:804C ByID : ....................: OK
Save the module:804D ByID : ....................: OK
Save the module:804E ByID : ....................: OK
Save the module:804F ByID : ....................: OK
Save the module:804A ByID : ....................: OK
Save the module:804B ByID : ....................: OK
Save the module:8050 ByID : ....................: OK
Save the module:8051 ByID : ....................: OK
Save the module:8052 ByID : ....................: OK
Save the module:8053 ByID : ....................: OK
Save the module:8054 ByID : ....................: OK
Save the module:8055 ByID : ....................: OK
Save the module:8056 ByID : ....................: OK
Save the module:8057 ByID : ....................: OK
Save the module:8058 ByID : ....................: OK
Save the module:8059 ByID : ....................: OK
Save the module:805A ByID : ....................: OK
Save the module:805B ByID : ....................: OK
Save the module:805C ByID : ....................: OK
Save the module:8066 ByID : ....................: OK
Save the module:8067 ByID : ....................: OK
Save the module:8068 ByID : ....................: OK
Save the module:8069 ByID : ....................: OK
Save the module:1420 ByID : ....................: OK
Save the module:120F ByID : ....................: OK
Save the module:1213 ByID : ....................: OK
Save the module:1450 ByID : ....................: OK
Save the module:1400 ByID : ....................: OK
Save the module:1207 ByID : ....................: OK
Save the module:1208 ByID : ....................: OK
Save the module:1206 ByID : ....................: OK
Module backup completed!
Saving tracks
Save Path:C:\UserDataFile\WDC Marvell\Tornado 2D\20190416-213656-00580076\Data\SABackup\Tracks\
Save track : 0128 - 0 : ........................: OK
Save track : 0128 - 1 : ........................: OK
Save track : 0127 - 0 : ........................: OK
Save track : 0127 - 1 : ........................: OK
Save track : 0126 - 0 : ........................: OK
Save track : 0126 - 1 : ........................: OK
Save track : 0125 - 0 : ........................: OK
Save track : 0125 - 1 : ........................: OK
Save track : 0124 - 0 : ........................: OK
Save track : 0124 - 1 : ........................: OK
Save track : 0123 - 0 : ........................: OK
Save track : 0123 - 1 : ........................: OK
Save track : 0122 - 0 : ........................: OK
Save track : 0122 - 1 : ........................: OK
Save track : 0121 - 0 : ........................: OK
Save track : 0121 - 1 : ........................: OK
Save track : 0120 - 0 : ........................: OK
Save track : 0120 - 1 : ........................: OK
Save track : 0119 - 0 : ........................: OK
Save track : 0119 - 1 : ........................: OK
Save track : 0118 - 0 : ........................: OK
Save track : 0118 - 1 : ........................: OK
Save track : 0117 - 0 : ........................: OK
Save track : 0117 - 1 : ........................: OK
Save track : 0116 - 0 : ........................: OK
Save track : 0116 - 1 : ........................: OK
Save track : 0115 - 0 : ........................: OK
Save track : 0115 - 1 : ........................: OK
Save track : 0114 - 0 : ........................: OK
Save track : 0114 - 1 : ........................: OK
Save track : 0113 - 0 : ........................: OK
Save track : 0113 - 1 : ........................: OK
Save track : 0112 - 0 : ........................: OK
Save track : 0112 - 1 : ........................: OK
Save track : 0111 - 0 : ........................: OK
Save track : 0111 - 1 : ........................: OK
Save track : 0110 - 0 : ........................: OK
Save track : 0110 - 1 : ........................: OK
Save track : 0109 - 0 : ........................: OK
Save track : 0109 - 1 : ........................: OK
Save track : 0108 - 0 : ........................: OK
Save track : 0108 - 1 : ........................: OK
Save track : 0107 - 0 : ........................: OK
Save track : 0107 - 1 : ........................: OK
Save track : 0106 - 0 : ........................: OK
Save track : 0106 - 1 : ........................: OK
Save track : 0105 - 0 : ........................: OK
Save track : 0105 - 1 : ........................: OK
Save track : 0104 - 0 : ........................: OK
Save track : 0104 - 1 : ........................: OK
Save track : 0103 - 0 : ........................: OK
Save track : 0103 - 1 : ........................: OK
Save track : 0102 - 0 : ........................: OK
Save track : 0102 - 1 : ........................: OK
Save track : 0101 - 0 : ........................: OK
Save track : 0101 - 1 : ........................: OK
Save track : 0100 - 0 : ........................: OK
Save track : 0100 - 1 : ........................: OK
Save track : 0099 - 0 : ........................: OK
Save track : 0099 - 1 : ........................: OK
Save track : 0098 - 0 : ........................: OK
Save track : 0098 - 1 : ........................: OK
Save track : 0097 - 0 : ........................: OK
Save track : 0097 - 1 : ........................: OK
Save track : 0096 - 0 : ........................: OK
Save track : 0096 - 1 : ........................: OK
Save track : 0095 - 0 : ........................: OK
Save track : 0095 - 1 : ........................: OK
Save track : 0094 - 0 : ........................: OK
Save track : 0094 - 1 : ........................: OK
Save track : 0093 - 0 : ........................: OK
Save track : 0093 - 1 : ........................: OK
Save track : 0092 - 0 : ........................: OK
Save track : 0092 - 1 : ........................: OK
Save track : 0091 - 0 : ........................: OK
Save track : 0091 - 1 : ........................: OK
Save track : 0090 - 0 : ........................: OK
Save track : 0090 - 1 : ........................: OK
Save track : 0089 - 0 : ........................: OK
Save track : 0089 - 1 : ........................: OK
Save track : 0088 - 0 : ........................: OK
Save track : 0088 - 1 : ........................: OK
Save track : 0087 - 0 : ........................: OK
Save track : 0087 - 1 : ........................: OK
Save track : 0086 - 0 : ........................: OK
Save track : 0086 - 1 : ........................: OK
Save track : 0085 - 0 : ........................: OK
Save track : 0085 - 1 : ........................: OK
Save track : 0084 - 0 : ........................: OK
Save track : 0084 - 1 : ........................: OK
Save track : 0083 - 0 : ........................: OK
Save track : 0083 - 1 : ........................: OK
Save track : 0082 - 0 : ........................: OK
Save track : 0082 - 1 : ........................: OK
Save track : 0081 - 0 : ........................: OK
Save track : 0081 - 1 : ........................: OK
Save track : 0080 - 0 : ........................: OK
Save track : 0080 - 1 : ........................: OK
Save track : 0079 - 0 : ........................: OK
Save track : 0079 - 1 : ........................: OK
Save track : 0078 - 0 : ........................: OK
Save track : 0078 - 1 : ........................: OK
Save track : 0077 - 0 : ........................: OK
Save track : 0077 - 1 : ........................: OK
Save track : 0076 - 0 : ........................: OK
Save track : 0076 - 1 : ........................: OK
Save track : 0075 - 0 : ........................: OK
Save track : 0075 - 1 : ........................: OK
Save track : 0074 - 0 : ........................: OK
Save track : 0074 - 1 : ........................: OK
Save track : 0073 - 0 : ........................: OK
Save track : 0073 - 1 : ........................: OK
Save track : 0072 - 0 : ........................: OK
Save track : 0072 - 1 : ........................: OK
Save track : 0071 - 0 : ........................: OK
Save track : 0071 - 1 : ........................: OK
Save track : 0070 - 0 : ........................: OK
Save track : 0070 - 1 : ........................: OK
Save track : 0069 - 0 : ........................: OK
Save track : 0069 - 1 : ........................: OK
Save track : 0068 - 0 : ........................: OK
Save track : 0068 - 1 : ........................: OK
Save track : 0067 - 0 : ........................: OK
Save track : 0067 - 1 : ........................: OK
Save track : 0066 - 0 : ........................: OK
Save track : 0066 - 1 : ........................: OK
Save track : 0065 - 0 : ........................: OK
Save track : 0065 - 1 : ........................: OK
Save track : 0064 - 0 : ........................: OK
Save track : 0064 - 1 : ........................: OK
Save track : 0063 - 0 : ........................: OK
Save track : 0063 - 1 : ........................: OK
Save track : 0062 - 0 : ........................: OK
Save track : 0062 - 1 : ........................: OK
Save track : 0061 - 0 : ........................: OK
Save track : 0061 - 1 : ........................: OK
Save track : 0060 - 0 : ........................: OK
Save track : 0060 - 1 : ........................: OK
Save track : 0059 - 0 : ........................: OK
Save track : 0059 - 1 : ........................: OK
Save track : 0058 - 0 : ........................: OK
Save track : 0058 - 1 : ........................: OK
Save track : 0057 - 0 : ........................: OK
Save track : 0057 - 1 : ........................: OK
Save track : 0056 - 0 : ........................: OK
Save track : 0056 - 1 : ........................: OK
Save track : 0055 - 0 : ........................: OK
Save track : 0055 - 1 : ........................: OK
Save track : 0054 - 0 : ........................: OK
Save track : 0054 - 1 : ........................: OK
Save track : 0053 - 0 : ........................: OK
Save track : 0053 - 1 : ........................: OK
Save track : 0052 - 0 : ........................: OK
Save track : 0052 - 1 : ........................: OK
Save track : 0051 - 0 : ........................: OK
Save track : 0051 - 1 : ........................: OK
Save track : 0050 - 0 : ........................: OK
Save track : 0050 - 1 : ........................: OK
Save track : 0049 - 0 : ........................: OK
Save track : 0049 - 1 : ........................: OK
Save track : 0048 - 0 : ........................: OK
Save track : 0048 - 1 : ........................: OK
Save track : 0047 - 0 : ........................: OK
Save track : 0047 - 1 : ........................: OK
Save track : 0046 - 0 : ........................: OK
Save track : 0046 - 1 : ........................: OK
Save track : 0045 - 0 : ........................: OK
Save track : 0045 - 1 : ........................: OK
Save track : 0044 - 0 : ........................: OK
Save track : 0044 - 1 : ........................: OK
Save track : 0043 - 0 : ........................: OK
Save track : 0043 - 1 : ........................: OK
Save track : 0042 - 0 : ........................: OK
Save track : 0042 - 1 : ........................: OK
Save track : 0041 - 0 : ........................: OK
Save track : 0041 - 1 : ........................: OK
Save track : 0040 - 0 : ........................: OK
Save track : 0040 - 1 : ........................: OK
Save track : 0039 - 0 : ........................: OK
Save track : 0039 - 1 : ........................: OK
Save track : 0038 - 0 : ........................: OK
Save track : 0038 - 1 : ........................: OK
Save track : 0037 - 0 : ........................: OK
Save track : 0037 - 1 : ........................: OK
Save track : 0036 - 0 : ........................: OK
Save track : 0036 - 1 : ........................: OK
Save track : 0035 - 0 : ........................: OK
Save track : 0035 - 1 : ........................: OK
Save track : 0034 - 0 : ........................: OK
Save track : 0034 - 1 : ........................: OK
Save track : 0033 - 0 : ........................: OK
Save track : 0033 - 1 : ........................: OK
Save track : 0032 - 0 : ........................: OK
Save track : 0032 - 1 : ........................: OK
Save track : 0031 - 0 : ........................: OK
Save track : 0031 - 1 : ........................: OK
Save track : 0030 - 0 : ........................: OK
Save track : 0030 - 1 : ........................: OK
Save track : 0029 - 0 : ........................: OK
Save track : 0029 - 1 : ........................: OK
Save track : 0028 - 0 : ........................: OK
Save track : 0028 - 1 : ........................: OK
Save track : 0027 - 0 : ........................: OK
Save track : 0027 - 1 : ........................: OK
Save track : 0026 - 0 : ........................: OK
Save track : 0026 - 1 : ........................: OK
Save track : 0025 - 0 : ........................: OK
Save track : 0025 - 1 : ........................: OK
Save track : 0024 - 0 : ........................: OK
Save track : 0024 - 1 : ........................: OK
Save track : 0023 - 0 : ........................: OK
Save track : 0023 - 1 : ........................: OK
Save track : 0022 - 0 : ........................: OK
Save track : 0022 - 1 : ........................: OK
Save track : 0021 - 0 : ........................: OK
Save track : 0021 - 1 : ........................: OK
Save track : 0020 - 0 : ........................: OK
Save track : 0020 - 1 : ........................: OK
Save track : 0019 - 0 : ........................: OK
Save track : 0019 - 1 : ........................: OK
Save track : 0018 - 0 : ........................: OK
Save track : 0018 - 1 : ........................: OK
Save track : 0017 - 0 : ........................: OK
Save track : 0017 - 1 : ........................: OK
Save track : 0016 - 0 : ........................: OK
Save track : 0016 - 1 : ........................: OK
Save track : 0015 - 0 : ........................: OK
Save track : 0015 - 1 : ........................: OK
Save track : 0014 - 0 : ........................: OK
Save track : 0014 - 1 : ........................: OK
Save track : 0013 - 0 : ........................: OK
Save track : 0013 - 1 : ........................: OK
Save track : 0012 - 0 : ........................: OK
Save track : 0012 - 1 : ........................: OK
Save track : 0011 - 0 : ........................: OK
Save track : 0011 - 1 : ........................: OK
Save track : 0010 - 0 : ........................: OK
Save track : 0010 - 1 : ........................: OK
Save track : 0009 - 0 : ........................: OK
Save track : 0009 - 1 : ........................: OK
Save track : 0008 - 0 : ........................: OK
Save track : 0008 - 1 : ........................: OK
Save track : 0007 - 0 : ........................: OK
Save track : 0007 - 1 : ........................: OK
Save track : 0006 - 0 : ........................: OK
Save track : 0006 - 1 : ........................: OK
Save track : 0005 - 0 : ........................: OK
Save track : 0005 - 1 : ........................: OK
Save track : 0004 - 0 : ........................: OK
Save track : 0004 - 1 : ........................: OK
Save track : 0003 - 0 : ........................: OK
Save track : 0003 - 1 : ........................: OK
Save track : 0002 - 0 : ........................: OK
Save track : 0002 - 1 : ........................: OK
There is an error in reading tracks:
Save track : 0001 - 0 : ........................: OK
Save track : 0001 - 1 : ........................: OK
Track backup completed!
Hard disk resource backup completed!
 Post subject: Re: WD3200AVJS-63WDA0 Zone allocation table error
PostPosted: April 17th, 2019, 2:24
Your ROM version and FW version are different by the sounds of it, so you’ll have to “manufacture” a new ROM from the modules you have saved.
I’m pretty sure MRT will have a feature for this, like “rebuild ROM SA data” in PC3K.
Or.. try and read ROM from or repair original PCB and write to new one.
PostPosted: April 18th, 2019, 7:27
Thank you guys. Sorry for my newbie questions... It worked perfectly :)
PostPosted: April 18th, 2019, 15:53
We were all newbies at one point! :-)
Users browsing this forum: No registered users and 136 guests
