 Post subject: Alignment of platters on a 7200.10 Drive
PostPosted: April 16th, 2019, 5:11
Hey Friends,
currently I have a Seagate 7200.10 (ST3400820AS) Drive on my table with a possible platter damage. I'd like to inspect the platters. Can some one tell me, if the alignment is critical on this drive? Or can I just put a mark on the side of the platters to align them again, when I'm done with the inspection?
 Post subject: Re: Alignment of platters on a 7200.10 Drive
PostPosted: April 16th, 2019, 7:27
you can
HddSurgery - Professional Data Recovery Tools
PostPosted: April 16th, 2019, 7:29
helpdisc wrote:
you can
Thank You!
PostPosted: April 16th, 2019, 7:41
when ever you have doubts , test on one donor. Label it and move them a bit.
PostPosted: April 18th, 2019, 3:26
Yeah, I know. But my problem with this model is, that I don't have any donor drives of the similar model. And when I buy a donor drive, I still can't try this out, because on this drive the heads are parked on the platter. And releasing the screws of the motor and twisting the platters can damage the heads. Same with removing them and putting again back on.
PostPosted: April 18th, 2019, 4:54
if just someone could invent a tool to move heads of :)
You can try on same family also.
PostPosted: April 19th, 2019, 13:34
i think no rotation align. but platter balancing is most important. i think this has 2 platters. there can be a hole under the pcb which covered by sticker. you can peel off and check platter 0. but you have to seal it again.
first you have to check the original head under microscope. after that you can decide next step.
Users browsing this forum: Doomer, Google [Bot] and 142 guests
