 Post subject: Hard drive weld damanged
PostPosted: April 24th, 2019, 6:30
by mistake, I damaged with a screwdriver the hard drive weld connector as seen in this picture the orange part with 4 weld points:
The last weld point on the photo is now missing, instead there is a very small hole, the size of the weld point.
Can anyone give me advice on how to repair it ? I guess welding a new point would be risky, as under are hard drive plates ?
Thanks you
 Post subject: Re: Hard drive weld damanged
PostPosted: April 24th, 2019, 17:51
Run a separate wire from point to point.
Users browsing this forum: Majestic-12 [Bot] and 254 guests
