 Post subject: Lots of error during LLF
PostPosted: May 7th, 2019, 4:50
I have replaced a 4TB HDD in my Synology because it has 743 bad blocks.
It still was working fine in the Syno, and the amount of bad blocks did not actually change for over a year ... I waited that long as I have two parity disks on the volume.
I would like to use that disk in my windows 10 pc as temporary storage, but I cannot format it.
When running LLF format I get those errors :
07/05/2019 10:38:19 Device capacity: 7,814,037,168 sectors
07/05/2019 10:38:19 Locking device...
07/05/2019 10:38:19 Formatting...
07/05/2019 10:38:23 Format Error occurred at offset 0: 1117 - Device I/O error
07/05/2019 10:38:27 Format Error occurred at offset 65,536: 1117 - Device I/O error
07/05/2019 10:38:32 Format Error occurred at offset 131,072: 1117 - Device I/O error
07/05/2019 10:38:36 Format Error occurred at offset 196,608: 1117 - Device I/O error
07/05/2019 10:38:41 Format Error occurred at offset 262,144: 1117 - Device I/O error
07/05/2019 10:38:45 Format Error occurred at offset 327,680: 1117 - Device I/O error
07/05/2019 10:38:50 Format Error occurred at offset 393,216: 1117 - Device I/O error
All the way to the end of the disk, offset modulo 65,536.
The readonly attribute is not set.
 Post subject: Re: Lots of error during LLF
PostPosted: May 8th, 2019, 11:46
Thanks for the hint. Even with victoria, read test was very slow, and write test was impossible.
It turned out to be a bad sata cable.
Users browsing this forum: Google [Bot] and 48 guests
