 Post subject: Do VelociRaptor and frame form an indissociable pair?
PostPosted: May 27th, 2019, 8:16
I have some 10K rpm WD VelociRaptors 2.5'' SATA hard drives, each one inserted in a radiator 3.5'' frame.
The model is WD1500HLFS-50G6U1.
All those drives have a sticker "Warranty void if removed" that will be broken if I unscrew the 2.5'' hard drive from its frame.
Apart from the radiator function, I want to understand the role of those frames, as each has a SATA to SATA circuit board and some sticker with parameters that look like those of regular Western Digital hard drives.
So, is there some calibration / optimization played by the adaptor frames?
Can the hard drives work correctly without them?
I have a potential buyer for the frames, but don't want to make the drives unusable. Hence my question.
 Post subject: Re: Do VelociRaptor and frame form an indissociable pair?
PostPosted: May 27th, 2019, 8:59
The heat sink frame is just that, nothing special with a passive pass-thru Sata connection as I remember.
But it is desirable to have them fitted if the drives are to be used for any length of time.
