 Post subject: Western Digital PCB compatibility if different VCM contoller
PostPosted: July 17th, 2019, 12:55
I'm planning a PCB swap for a WD Elements hard drive.
Although a new USB 3.0 board would do the job, I plan switching the circuit board to SATA, as a more durable solution after the drive was repaired.
I could find the compatible SATA board and the MCU controllers are same.
However the VCM (Voice Coil Motor) controllers are different (first 3 letters are same).
Is there some compatibility rule for this component?
patient's VCM: B20AA
donor's VCM: B20B8N4
(N.B. I'm aware about swapping the U12 chip.)
 Post subject: Re: Western Digital PCB compatibility if different VCM conto
PostPosted: July 17th, 2019, 12:59
What is the PCB number?
Also this drive may be encrypted, do you need the data?
PostPosted: July 17th, 2019, 13:04
PostPosted: July 17th, 2019, 13:24
unknown wrote:
You can copy and paste, well done.
PostPosted: July 17th, 2019, 16:54
I can copy and paste beside I can distinguish between encrypted WD and not encrypted.
PostPosted: July 17th, 2019, 16:59
You are of course correct, I didn't notice that.
PostPosted: July 17th, 2019, 17:02
That's what I tried to say. No offence at all
PostPosted: July 17th, 2019, 17:16
To all others who may be confused by this exchange, Elements models are not encrypted.
PostPosted: July 17th, 2019, 17:20
Just swap. 99% i haven't bothered while changing/converting from usb 3 to sata boards...specially the 961s to 960s...works.
Users browsing this forum: No registered users and 65 guests
