 Post subject: Seagate 7200.12 refurbished recovery
PostPosted: August 18th, 2019, 13:19
For entire week we are struggling with one refurbished seagate Pharoh family disk (7200.12 /320gb)
It gets detected normally with different model /sn/fw no. and tends to be busy all the time (refurbed model name).
Translator recovery is not been able to possible despite all efforts.
Can someone pls.guide , I can give remote access to UDMA-E , refurbed drives are not fully supported by utility.
 Post subject: Re: Seagate 7200.12 refurbished recovery
PostPosted: August 18th, 2019, 14:08
can you share the terminal log ? can you access SA ?
Data Recovery Pakistan
PostPosted: August 19th, 2019, 2:39
hi
terminal get locked & is not responding to read channel short procedure.
it shows following briefly ----
PostPosted: August 19th, 2019, 5:01
and what about SA, can you access any sysfile ?
PostPosted: August 19th, 2019, 9:27
Here is a similar case:
https://forum.hddguru.com/viewtopic.php?f=11&t=38069
IMHO you have no diagnostic overlays on it. Or they are not compatible with ROM. You need to change the firmware version to the stock one on it and fill in the necessary overlays. This, of course, if the writing heads is alive.
PostPosted: August 20th, 2019, 1:26
Hi MindMergepk
No dont have access to SA , I cant read sysfiles
PostPosted: August 20th, 2019, 1:29
Thanks E123,
You must be having quite a lot expertise to deal with such complications :D
Unfortunately I have done procedure you have described , however heads seems to be in working condition though I cant check resistance .
I am attaching ROM for further reference.
PostPosted: August 20th, 2019, 1:31
disk is giving led error now.
here is ROM.
ROM.rar [437.19 KiB]
Downloaded 922 times
PostPosted: August 20th, 2019, 2:51
Try to start with this ROM:
https://yadi.sk/d/_wyNTF05AiX_Ng
PostPosted: August 20th, 2019, 3:23
WO you are great E123 :good: , I just wrote your rom and now can read SA like normal hard disk. I have got full sector access & getting good imaging speed (heads are ok). But fight is not over yet , I am not able to read MFT's of any partition and getting read errors.
Further work on defect list / translator might be needed.
Thanks a ton for all the help. I will be in touch with you on PM. :D
PostPosted: August 20th, 2019, 5:06
With precise rom from E123 ,this case has been declared 100% solved. I have established full access to data .
Thanks E123. :D
PostPosted: August 21st, 2019, 6:01
hello E123 what was the issue , how you have solved the case. Have you modified original native ROM ?
otherwise how different rom is matched without apatives ?
PostPosted: August 21st, 2019, 6:06
nice work.
PostPosted: August 21st, 2019, 6:48
terminator2, Nothing special. Adaptives from refarbed flash I placed in a flash from the stock CC49.
MindMergepk, Thanks
PostPosted: August 21st, 2019, 8:28
SIR
you are really GREAT
Users browsing this forum: Google [Bot] and 210 guests
