 Post subject: WD5000AAKX-083CA1 rebuilding ROM
PostPosted: August 31st, 2019, 2:32
I have a WD5000AAKX-083CA1 drive that I am looking to access the SA to rebuild the ROM module. I have seen that SA access can be accomplished using a hotswap with a similar board. I have tried this without success. I have a 1 month license for wdmarvel. It looks like I need to recalibrate the drive using an ATA command. I am not sure how to do this. The original ROM chip is lost.
 Post subject: Re: WD5000AAKX-083CA1 rebuilding ROM
PostPosted: September 1st, 2019, 19:34
who says you can always rebuild the ROM from SA ?
but even it is possible to do
the procedure doesn't start with a similar board
it starts with a similar ROM
also it has noting to do with HS
PostPosted: September 1st, 2019, 20:18
Here is a picture of the drive in question.
Users browsing this forum: Google [Bot] and 66 guests
