BGman wrote:
You don't have any idea how the Toshiba drives work, do you?
To start the media firmware the drive has to read DD.bin and some other modules from surface 3.
Otherwise it runs the Flash firmware and the access to platters is blocked...
Some terminal commands could help in your case , but I doubt they are implemented in MRT or PC3K...
Yes I dont know much about DR and Toshiba drives. But;
I removed PCB from drive. And MRT recognised drive info and reading ROM and ROM modules. Showing head numbers . And Zone tables. Meaning, head map in ROM
MQABD Series like this. MK series not like this.
Selected family:MQ01ABD
Model:TOSHIBA MQ01UBD100
Load Zones : .........................:OK
Cyl Num : ............................:218356
Head Num : ...........................:4
Vendor : .............................:TOSHIBA
Model : ..............................:MQ01ABD100
Microcode : ..........................:AXF01UA9
G-List Reading : .....................:Err
CP list:33,34,44,56,92,95,98,9A,9C,A2,A5,A7,
A8,A9,AA,AD,AE,B1,B3,BB,BF,C1,C5,C6,C7,C8,
C9,CB,CD,D0,D1,D3,D4,D6,D7,D9,DA,DB,DC,
DD,EF,F1,F3,F4,F7,F8,FA,FB,FC,FF
Saving CP module......
Save to folder:C:\UserDataFile\Toshiba\MQ01ABD\sil20190902-230804\Data\CP\
33 : .................................:Err
34 : .................................:OK
44 : .................................:OK
56 : .................................:OK
92 : .................................:OK
95 : .................................:OK
98 : .................................:OK
9A : .................................:OK
9C : .................................:OK
A2 : .................................:OK
A5 : .................................:OK
A7 : .................................:OK
A8 : .................................:OK
A9 : .................................:OK
AA : .................................:OK
AD : .................................:OK
AE : .................................:OK
B1 : .................................:OK
B3 : .................................:OK
BB : .................................:OK
BF : .................................:Err
C1 : .................................:OK
C5 : .................................:OK
C6 : .................................:OK
C7 : .................................:OK
C8 : .................................:OK
C9 : .................................:Err
CB : .................................:OK
CD : .................................:OK
D0 : .................................:OK
D1 : .................................:OK
D3 : .................................:Err
D4 : .................................:OK
D6 : .................................:OK
D7 : .................................:OK
D9 : .................................:OK
DA : .................................:OK
DB : .................................:OK
DC : .................................:OK
DD : .................................:Err
EF : .................................:OK
F1 : .................................:OK
F3 : .................................:OK
F4 : .................................:Err
F7 : .................................:Err
F8 : .................................:Err
FA : .................................:OK
FB : .................................:OK
FC : .................................:Err
FF : .................................:OK
CP Saving module is ok!
NN * Head 0
NN * Beg Cyl : End Cyl : SPT
00 * 0 : 5687 : 2992
01 * 5688 : 11454 : 2944
02 * 11455 : 17221 : 2936
03 * 17222 : 22988 : 2888
04 * 22989 : 28834 : 2880
05 * 28835 : 34838 : 2760
06 * 34839 : 40842 : 2752
07 * 40843 : 46925 : 2712
08 * 46926 : 53166 : 2632
09 * 53167 : 59328 : 2616
10 * 59329 : 65569 : 2568
11 * 65570 : 71889 : 2496
12 * 71890 : 77972 : 2568
13 * 77973 : 84134 : 2496
14 * 84135 : 90296 : 2496
15 * 90297 : 96537 : 2400
16 * 96538 : 102699 : 2408
17 * 102700 : 109019 : 2304
18 * 109020 : 115181 : 2336
19 * 115182 : 121343 : 2288
20 * 121344 : 127584 : 2216
21 * 127585 : 133825 : 2168
22 * 133826 : 140066 : 2120
23 * 140067 : 146149 : 2120
24 * 146150 : 152390 : 2024
25 * 152391 : 158631 : 1976
26 * 158632 : 164793 : 1976
27 * 164794 : 170876 : 1896
28 * 170877 : 176880 : 1872
29 * 176881 : 182884 : 1792
30 * 182885 : 188809 : 1752
31 * 188810 : 194655 : 1704
32 * 194656 : 200422 : 1664
33 * 200423 : 206189 : 1608
34 * 206190 : 211956 : 1560
35 * 211957 : 217644 : 1512
36 * 217645 : 217716 : 1480
37 * 217717 : 217876 : 2184
38 * 217877 : 218356 : 2184
NN * Head 1
00 * 0 : 5055 : 3168
01 * 5056 : 10190 : 3120
02 * 10191 : 15325 : 3096
03 * 15326 : 20539 : 3024
04 * 20540 : 25753 : 3016
05 * 25754 : 31046 : 2928
06 * 31047 : 36339 : 2912
07 * 36340 : 41632 : 2896
08 * 41633 : 47083 : 2784
09 * 47084 : 52534 : 2768
10 * 52535 : 58064 : 2720
11 * 58065 : 63515 : 2728
12 * 63516 : 68966 : 2712
13 * 68967 : 74417 : 2688
14 * 74418 : 79868 : 2664
15 * 79869 : 85398 : 2608
16 * 85399 : 91007 : 2568
17 * 91008 : 96616 : 2496
18 * 96617 : 102304 : 2408
19 * 102305 : 107913 : 2408
20 * 107914 : 113522 : 2360
21 * 113523 : 119131 : 2304
22 * 119132 : 124740 : 2256
23 * 124741 : 130349 : 2208
24 * 130350 : 135958 : 2160
25 * 135959 : 141567 : 2112
26 * 141568 : 147176 : 2056
27 * 147177 : 152785 : 1984
28 * 152786 : 158236 : 1936
29 * 158237 : 163687 : 1872
30 * 163688 : 169059 : 1808
31 * 169060 : 174352 : 1760
32 * 174353 : 179566 : 1712
33 * 179567 : 184780 : 1640
34 * 184781 : 189915 : 1608
35 * 189916 : 195050 : 1544
36 * 195051 : 195115 : 1512
37 * 195116 : 195275 : 2184
38 * 195276 : 195755 : 2184
NN * Head 2
00 * 0 : 5845 : 3024
01 * 5846 : 11691 : 3016
02 * 11692 : 17537 : 2976
03 * 17538 : 23541 : 2888
04 * 23542 : 29545 : 2880
05 * 29546 : 35628 : 2832
06 * 35629 : 41711 : 2816
07 * 41712 : 47794 : 2808
08 * 47795 : 54035 : 2720
09 * 54036 : 60276 : 2712
10 * 60277 : 66517 : 2688
11 * 66518 : 72758 : 2640
12 * 72759 : 78999 : 2600
13 * 79000 : 85240 : 2576
14 * 85241 : 91560 : 2496
15 * 91561 : 97801 : 2496
16 * 97802 : 104121 : 2408
17 * 104122 : 110441 : 2376
18 * 110442 : 116761 : 2336
19 * 116762 : 123002 : 2288
20 * 123003 : 129322 : 2216
21 * 129323 : 135642 : 2168
22 * 135643 : 141883 : 2136
23 * 141884 : 148124 : 2088
24 * 148125 : 154365 : 2048
25 * 154366 : 160606 : 1992
26 * 160607 : 166847 : 1928
27 * 166848 : 173088 : 1856
28 * 173089 : 179171 : 1832
29 * 179172 : 185175 : 1792
30 * 185176 : 191100 : 1736
31 * 191101 : 196946 : 1688
32 * 196947 : 202792 : 1640
33 * 202793 : 208638 : 1576
34 * 208639 : 214484 : 1512
35 * 214485 : 220251 : 1480
36 * 220252 : 220324 : 1456
37 * 220325 : 220484 : 2184
38 * 220485 : 220964 : 2184
NN * Head 3
00 * 0 : 5371 : 3168
01 * 5372 : 10901 : 3048
02 * 10902 : 16510 : 3008
03 * 16511 : 22119 : 2992
04 * 22120 : 27728 : 2976
05 * 27729 : 33337 : 2960
06 * 33338 : 38946 : 2944
07 * 38947 : 44555 : 2896
08 * 44556 : 50243 : 2816
09 * 50244 : 55931 : 2824
10 * 55932 : 61619 : 2784
11 * 61620 : 67307 : 2728
12 * 67308 : 72995 : 2688
13 * 72996 : 78762 : 2632
14 * 78763 : 84529 : 2576
15 * 84530 : 90296 : 2560
16 * 90297 : 96063 : 2496
17 * 96064 : 101909 : 2432
18 * 101910 : 107755 : 2376
19 * 107756 : 113522 : 2368
20 * 113523 : 119368 : 2288
21 * 119369 : 125214 : 2240
22 * 125215 : 131060 : 2192
23 * 131061 : 136906 : 2136
24 * 136907 : 142752 : 2088
25 * 142753 : 148598 : 2040
26 * 148599 : 154444 : 1992
27 * 154445 : 160290 : 1920
28 * 160291 : 166136 : 1848
29 * 166137 : 171982 : 1792
30 * 171983 : 177749 : 1752
31 * 177750 : 183516 : 1704
32 * 183517 : 189204 : 1664
33 * 189205 : 194892 : 1608
34 * 194893 : 200580 : 1544
35 * 200581 : 206268 : 1480
36 * 206269 : 206340 : 1456
37 * 206341 : 206500 : 2184
38 * 206501 : 206980 : 2184
Total number of physical sectors:1969143360
Total number of logical sectors:1953525168
