September 24th, 2014, 13:43
Anybody experienced the same ever?
Drive clicks, and produces the following in terminal...
SPUP
SPOK
UR: 0002
1UR: 0002
1UR: 0002
1UR: 0002
1UR: 0002
1UR: 0002
1UR: 0002
1UR: 0002
Sb
CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! CHNL Cal OK
! Sb
September 25th, 2014, 6:59
Problem already Identified
September 26th, 2014, 8:20
can you report solution?
thanks
September 26th, 2014, 11:07
Previous Expert/Shop changed the original PCB with a incompatible/wrong PCB.
Correct PCB replacement did the trick.
September 26th, 2014, 16:50
ooooh, that is the trick!!
Good one
September 28th, 2019, 8:38
I just found a same model hdd with same log
�SPUP
SPOK
UR:0004
1UR:0004
1UR:0004
1UR:0004
1UR:0004
1UR:0004
1UR:0004
1UR:0004
Sb
Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Chnl Cal OK
!Sb
September 29th, 2019, 2:46
Check if previous man used the wrong PCB! If still not solved, I can help
