 Post subject: Nvme SSD adapters
PostPosted: September 20th, 2019, 5:28
Hello friends
I am looking for NvMe SSD adapter for cloning and DR purpose. I think USB will be better choice as USB may get detected in most cloning softwares.
Pci express based adapters will need a desktop and there is drivers related issues in those adapters.
Can you pls.suggest best reviewed model ?
here is one of the available model --
ORICO Mini M.2 NVME SSD Enclosure Push-Open Aluminum NVME External Hard Drive Case USB3.1 Gen2 Type-C up to 2TB 10Gbps (Silver)
https://www.newegg.com/p/0VN-0003-001D4
ORICO Aluminium M.2 SSD Enclosure for M.2 NVMe SSD to USB 3.1 Gen2 Type-C Mini SSD Case Clip 10Gbps Support UASP Protocol With Type-C to C Cable
 Post subject: Re: Nvme SSD adapters
PostPosted: September 20th, 2019, 15:50
There is at least one such adapter with a physical write protect switch.
NVMe - USB 3 adapters for M.2 SSDs:
http://www.hddoracle.com/viewtopic.php?f=106&t=2853
PostPosted: September 21st, 2019, 1:03
Hi fzabkar :good:
Thanks for the information. So many new technologies are coming. USB 4.0 is coming and USB 3.2 products are not yet introduced.
Heat is biggest concern as temprature often reaches 70 degrees. UASP protocol is some of them have advertised .
Users browsing this forum: No registered users and 91 guests
