 Post subject: Samsung hn-m500bb BSY
PostPosted: October 5th, 2019, 11:30
Hi guys I have a samsung hn-m500mbb that remains in BSY status, it doesn't make noise and you don't feel strange starts, everything is regular at first sight. I enclose the log thanks to all:ActiveFW : 00FWVer : 0001SATA PLL cal doneDDR size detected = 8MB DDR size detected = 8MB*PAUNI_L2957*PA VID=0006 PN=0009 Rev=0002- PA_UNI Found*PAUNI_L2957*PA VID=0006 PN=0009 Rev=0002- PA_UNI FoundU
S_0SHK NF Cal:27
SO_1
SPU@32'C,4989mV
IS=3
CLA ..36/74
HO..OK
HO RPM=3197 OK
AC 802
ST..OK
mS1 00000003
GT:423
SC(L):4123/26
BE.N:18
LD..OK
SK C: 7216 H:0
Loaded FIT ( 0: 0: 1)
CalibTable Loaded. Rev:0x1B
ResoTable Loaded. Rev:0x01
Bump Limit Loaded. Rev:0x01
RRO1xTable Loaded. Rev:0x01
Fw Active 00
Ovly NOT loaded
 Post subject: Re: Samsung hn-m500bb BSY
PostPosted: October 5th, 2019, 15:15
magnetepazzo wrote:
Ovly NOT loaded
Bad sectors in SA?!?
PostPosted: October 5th, 2019, 15:34
It's possible, suggestions?
PostPosted: October 5th, 2019, 16:19
I am not sure but ,I remember this , ROM not original or weak / bad head . Only guess
Not sure
Sexy Womans from your town
PostPosted: October 5th, 2019, 16:53
the problem is that even if I send a reset it does not react, it remains in bsy. I can't get him to do anything I want. I have access to the modules of the sa but if I try to copy them it remains locked to infinity
PostPosted: October 5th, 2019, 19:42
AIUI …
    1/ Find a compatible donor with the same preamp
    2/ Perform a hot swap
    3/ Read SA modules from patient HDD
    4/ Write important patient modules to donor SA (eg defect lists)
    5/ Perform a smart hot swap
If the MOVLY001 module is damaged, then there is a way to truncate it in order to avoid any damaged sectors at the end. However, this may not be necessary for a smart hot swap.
PostPosted: October 6th, 2019, 0:56
I try it thanks
PostPosted: October 7th, 2019, 11:22
Wrong PCB Firmware . Use DV command to find out the current F/W revision . It could be:
2BA6gbnM.d82 , 2BA6gc3M.d82 or 2BA6gbzM.d82 ...(PCB only)
Try PCB with other F/W...
Users browsing this forum: Google [Bot], melvin, servohunter and 96 guests
