Anyone experienced similar cases in SAS?
November 6th, 2019, 8:00
Hello guys,,,
I got a strange case here in SAS where the drive Spins normal but Heads never moves...
its like the power is feeding the Motor & spinning @ normal speed but Heads like stuck but its not (when i move it manually its Ok not stuck)
Anyone had similar cases?
thnx
Re: Anyone experienced similar cases in SAS?
November 6th, 2019, 12:54
Usually an indicator of bad heads
November 6th, 2019, 16:06
Doomer wrote:Usually an indicator of bad heads
And/or media damage
November 6th, 2019, 17:19
And/or media damage
Could be media damage that initially destroyed heads.
November 7th, 2019, 4:48
Humm, the options are:
Heads or Media damaged
The only thing that is annoying here is that Spinning up process is normal (I compared it with one of the working drives same model exactly)
and the spinning up process reaches a level where Motor spins normal then some certain init. time and Heads starts to move (it doesn`t in my case example)
seems i have only one option left to try here
Thank you all guys for the advice/comments...
