 Post subject: Grenada ST1000DM003 - BSY
PostPosted: November 7th, 2019, 6:31
Hello friends. I'm here only to be sure that my diagnosis isn't erroneous.
This Grenada came to me with the PCB completely destroyed by an IT store.
Changed the PCB and I'm getting this on terminal:
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
TCC-001E[0x000042F9][0x000042F9]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWW
PreampFaultStatus = 0000YWMMMMMM
Drive doesn't sound weird and stays on BSY all time.
This is clearly a preamp problem, right? Is there any chance to be anything else?
Thank you so much for any reply.
 Post subject: Re: Grenada ST1000DM003 - BSY
PostPosted: November 7th, 2019, 6:34
Did you swap rom to the new pcb?
PostPosted: November 7th, 2019, 7:17
bojack, Yes.. it's spinning and heads are posting (hearing through a stethoscope). Sounds are totally normal.
PostPosted: November 7th, 2019, 7:29
Did you check the rom before? I guess ROM is not native. Do you have a pc3k or any special tools?
PostPosted: November 7th, 2019, 7:36
Firstly check Hdd id, serial number etc from the Rom.
PostPosted: November 7th, 2019, 7:44
I have a MRT pro.. didn't check the ROM... now that you said it's really possible that this IT store changed ROM or something like that.
Where exectly on ROM dump should I serch for this, please?
I'll check this today and I will come back.
Thank you for your reply.
PostPosted: November 7th, 2019, 8:04
I could tell but I never used Mrt.
PostPosted: November 7th, 2019, 8:16
bojack, I believe it will be on .bin hexadecimals from ROM, right? This can be readed with any hexadecimal editor, right?
PostPosted: November 7th, 2019, 8:22
If you can read the rom and upload it here, i can check for you.
PostPosted: November 7th, 2019, 8:25
Ok, thank you. I'll do this ASAP.
PostPosted: November 7th, 2019, 16:14
Where was the damage on the original PCB? If the 5V TVS diode is shorted or missing, then the preamp may have been damaged as well.
Check the ROM's CAP module for the serial number and model number.
PostPosted: November 7th, 2019, 18:09
fzabkar, It were totally destroyed. Some animal tried to "reflow" MCU and drive controller chip. Lot's of poor flux. It was a mess.
But it really can be other PCB, not the original, judging by what they made to this poor PCB.
I'm sending the ROM .bin. Where exactly should I search for serial and ID?
On label serial is Z1D09FLM
PN: 9YN162-570
FW: CC98
Thank you again for all your help.
ROM-20191107082455.rar [178.25 KiB]
Downloaded 696 times
PostPosted: November 7th, 2019, 18:18
Found it... this isn't the device's label ID... now I will ask him if he can contact the IT store that committed this crime.
PostPosted: November 7th, 2019, 18:19
F3RomExplorer should be able to parse the ROM for you.
http://www.hddoracle.com/download/file.php?id=7643
PostPosted: November 7th, 2019, 19:04
fzabkar, Nice, Thank you :)
This PCB has two SOIC 8, one next to the other.
My donor PCB have two, but the original PCB came with only one.
What is the difference?
The PCB is 100664987 REV B
PostPosted: November 8th, 2019, 5:45
Not much surprise. For some reason the original card is always lost. :evil:
PostPosted: November 9th, 2019, 13:18
What are the markings on the ICs?
Users browsing this forum: Google [Bot] and 41 guests
