 Post subject: Password Locked HITACHI HDN726060ALE610
PostPosted: December 4th, 2019, 2:03
I have a HITACHI HDN726060ALE610 which is password locked.
When connected to PC-3K it says ATTENTION ! Security-Locked HDD.
Any suggestions to Unlock it.
 Post subject: Re: Password Locked HITACHI HDN726060ALE610
PostPosted: December 4th, 2019, 3:34
This error also occurs when the heads are bad and/or the drive cannot read from SA.
PostPosted: December 4th, 2019, 14:44
MRT I believe has clearing password feature so I would expect PC 3000 should as well ?
PostPosted: December 4th, 2019, 15:37
Not for this model they haven’t.
PostPosted: December 5th, 2019, 11:59
May upload the nvram here .
PostPosted: December 5th, 2019, 12:04
Yeah, that's a pickle
No NVRAM on this model
PostPosted: December 6th, 2019, 10:23
Those drives are not supported by any tool. And over all are not very reliable compared to previous HGST drives. If this drive locked itself out that there is a very good chance that the heads are bad. Could you upload SMART data, it may take a while before Windows allows you to see the drive.
PostPosted: December 7th, 2019, 0:08
+1
PostPosted: July 23rd, 2024, 5:09
Hello ALL
Has anyone troed head exchange in this drive.
My question is whether whether head swap works in this family without any modification in ROM
Any help will be appreciated.
PostPosted: July 24th, 2024, 12:53
I hate these models, rarely had a successful HSA replacement, and usually, SA gets damaged when heads get damaged
PostPosted: July 25th, 2024, 6:18
In two ok HDD interchanged heads, HDD detects PCB only, spinning normal but no sector edit.
After go back both HDD works fine.
Users browsing this forum: Google [Bot] and 70 guests
