Mariner
December 9th, 2019, 12:17
Hello
Need full resources for this one : 0001100FU
Thanks in advance
Re: Mariner
December 9th, 2019, 12:21
What model?
Re: Mariner
December 9th, 2019, 12:44
WDC WD5000BEVT-00A0RT0-01.01A01
Re: Mariner
December 10th, 2019, 6:19
Here.
Good luck.
WDC WD5000BEVT-00A0RT0-01-01A01-WD-WXF0A9938341.rar
(1.33 MiB) Downloaded 403 times
Re: Mariner
December 10th, 2019, 10:42
@ northwind
Thanks a lot.
You are the best, the drive worked like a charm. :good:
Re: Mariner
December 10th, 2019, 11:34
The drive came to me opened before ( in reputable DR company in Dubai ) reported unrecoverable.
The big problem that they gave the drive to the customer ( with fingerprints, debris, ring to the outer, broken heads and PCB without ROM )
I couldn't believe until I saw the company label on the drive.
Imaging in progress (23.6%) and trying to leave the bad zones to the end.
Re: Mariner
December 10th, 2019, 15:52
unknown wrote: they gave the drive to the customer ( with fingerprints, debris, ring to the outer, broken heads and PCB without ROM )
And they're reputable??? :shock: :shock:
Re: Mariner
December 10th, 2019, 15:53
unknown wrote:@ northwind
Thanks a lot.
Glad it worked out for you! :) :D
Re: Mariner
December 11th, 2019, 7:41
Unfortunately, yes.
Thanks a lot.
Thanks a lot my friend.
BTW, Mariner, Jamaica and Zephyr are close friends :D
Re: Mariner
December 14th, 2019, 8:30
After taking 91.8% of good image, the contents of the drive is not related to the customer data. ( The data related to a Thailand guy and his family pictures :)
Entire customer's drive replaced.
What should I do with the customer at this case?
Re: Mariner
December 14th, 2019, 9:00
unknown wrote:After taking 91.8% of good image, the contents of the drive is not related to the customer data. ( The data related to a Thailand guy and his family pictures :)
What a nightmare :?
Tell your client the truth, I would not charge a case like that.
Hopefully he will get his "real" drive back.
Re: Mariner
December 14th, 2019, 9:21
Sure I won't charge any fee from the client.
I always charge when I get a result. ( Even If I already exhausted 3 donors :( )
But after this, the customer told me the rest of the story that the drive was in Egypt too at another companies.
So, there's no one can tell where the original drive really went. :)
