 Post subject: Power off durng LoLvlFmt
PostPosted: January 15th, 2020, 10:46
OS: WinXP. External hard drive adapter
Unfortunately during a Low Level Format, the power was cut.
Now I cannot any longer see the drive in File Explorer (although LowLevelFormat can but without drive letter).
If I put another drive in the external drive adapter it can be seen and a drive letter assigned.
If I connect the external adapter to another computer it reccognises the drive and assigns a drive letter but reports size as zero bytes (actually 1 Tb).
Any good suggestions? Thank you (I have a System backup from prev day!)
Regards & Thanks Agolindo
 Post subject: Re: Power off durng LoLvlFmt
PostPosted: January 16th, 2020, 4:54
Control Panel / disk management / format (or create) partition
PostPosted: January 16th, 2020, 15:38
Consider getting an UPS for the stuff doing critical work?
"Take care of thy backups and thy restores shall take care of thee." Ben Franklin revisited
Users browsing this forum: No registered users and 256 guests
