 Post subject: WD40NMZW-11GX6S1 PCB to SATA
PostPosted: March 26th, 2019, 14:56
Hello, according to the topic https://forum.acelaboratory.com/viewtopic.php?t=9615 tried to figure out the connection of the pins 2,3,5,6. i read at the topic that https://blog.acelaboratory.com/pc-3000- ... drive.html could help of how to connect pins. could someone help me with this USB PCB where to solder each pin? e.g Pin 2 with E71, Pin 3 with E72.
Thank you in advance
P.S. When will WD40NPZZ-00PDPT0 with compatible Sata pcb 2060-800022-002 will be available in Europe in a fair price? :? :? :?
 Post subject: Re: WD40NMZW-11GX6S1 PCB to SATA
PostPosted: March 26th, 2019, 14:58
Pictures with all the numbers
https://imgur.com/LdT6YM8
You'd need very short wires - 15-20mm max to make it work
PostPosted: March 26th, 2019, 15:13
Thank you for your fast reply. i saw that picture on a previous post, but it doesn't assign which pin goes where (E71,E72,E73,E75). at the example which ACE has at its blog says that "Pins 2 should be soldered to the minor marked text point on the PCB. In this case it’s “C90”. All other SATA adapter contacts soldering from the minor text to the major." but for another PCB. What about this one?
PostPosted: March 26th, 2019, 15:35
it does, the picture on the right has the SATA pin numbers, look closely, they are pretty small but still visible
PostPosted: March 26th, 2019, 15:51
SATA pin #    PCB ref
2             E71
3             E72
5             E73
6             E75
PostPosted: March 27th, 2019, 1:58
It is available almost everywere.
There is a USB drives with known brand almost in every shop. 125-135USD new one. Check your PM
Angel Data Recovery
PostPosted: December 20th, 2019, 13:23
Hello, I try the same mod...
https://imgur.com/LdT6YM8 shows PCB 2060-800041-000 REV P1... Are the capacitors which I need to remove still the same for PCB 2060-800041-003 REV P1?
The PCB looks pretty similiar but not 100% the same. I found on that spot 4 brown SMDs and so i am pretty sure that are capacitors but I am not sure if the layout changed... In the picture look the capacitors also much bigger - the ones in my PCB are extreme tiny, at lease they appear tinier then in the picture.
Is the pinout
PIN 2 (A+) -> E71
PIN 3 (A-) -> E72
PIN 5 (B-) -> E73
PIN 6 (B-) -> E75
for all WD USB-drives the same or is that only for that model valid?
PostPosted: December 21st, 2019, 18:33
Look at the pins of the bridge IC. If the components on your PCB connect to those same pins, and if your PCB has the same bridge IC, then ...
PostPosted: December 31st, 2019, 7:56
Hi. I had a problem with one of the leads and the soldering spot come off.
Where could i connect the lead else? I see two fine llines (A + C) and a bigger copper Area (B):
