 Post subject: my passport aide
PostPosted: January 20th, 2020, 5:47
Hello
I'm just starting to repair a hard drive and I need some help. I have a WD external drive My passport
with a 500giga disk Model: WD5000LMVW in USB.
The hard disk starts up but after 5 minutes it disconnects by itself. I think it's a PCB problem, so I wanted to change the PCB, I found the same one, but I wonder if instead of putting a pcb usb we can put a pcb sata.
Here is the reference 2060-771859-000 REV-P1
Thank you for your advice
Sorry for the translation, it's done for a translator.
 Post subject: Re: my passport aide
PostPosted: January 20th, 2020, 7:49
99% NOT the PCB.
But if you really want to try then you’ll need same USB PCB and switch “ROM” chip @ U12. Careful though, if you damage U12 chip then it’s pretty much “game over”.
You could switch to a SATA PCB but your data would be encrypted.
Much more likely to be a firmware and/media issue, or possibly a bad/weak head.
PostPosted: January 20th, 2020, 13:33
angoul wrote:
Hello
It's no PCB case 99.9999%
Bad sector in SA or user area or head problem.
SATA PCB could be solution with desktop .
But Risky for drive . Data would be gone forever .
Sexy Womans from your town
PostPosted: January 20th, 2020, 15:56
thank you for all your information, what do you suggest as a solution, because i'm just starting out and i don't want to make any mistakes.
PostPosted: January 20th, 2020, 17:07
Send it to a professional with the right equipment and knowledge to recover it.
Shouldn’t be too expensive at this stage before DIY tampering :-)
PostPosted: January 20th, 2020, 17:29
Hello
If I want to learn, I'm not going to learn by sending the disk.
I'm asking you to learn.
Thank you
PostPosted: January 20th, 2020, 17:48
What is the drive doing in those 5 minutes before it disconnects? Can you retrieve any data? Can you retrieve a SMART report with a tool such as CrystalDiskInfo?
PostPosted: January 21st, 2020, 11:29
Historical background:
The disc belongs to a person who drops it...
She told me she had some stuff on it.
Plugging in the disc:
It's not recognized in explorer, not Windows, not Mac OS, not Linux.
impossible to make an image, even with DDRESCUE
In disk management, it asks to initialize it while there are documents on it.
What to do then to retrieve the information, without of course going through a service provider.
Here's the connection made with crystaldisk
But for me it doesn't tell me what to do.
WDC WD5000LMVW-11CKRS0
Enclosure : WD My Passport 07A8 USB Device (V=1058, P=07A8, sa2) - wd
Model : WDC WD5000LMVW-11CKRS0
Firmware : 01.01A01
Serial Number : WD-WX61A92D4115
Disk Size : 500,0 GB (8,4/137,4/500,0/500,0)
Buffer Size : 8192 KB
Queue Depth : 32
# of Sectors : 976707633
Rotation Rate : 5400 RPM
Interface : USB (Serial ATA)
Major Version : ATA8-ACS
Minor Version : ----
Transfer Mode : SATA/300 | SATA/300
Power On Hours : 96 heures
Power On Count : 100 x
Temperature : 28 C (82 F)
Health Status : Prudence
Features : S.M.A.R.T., APM, 48bit LBA, NCQ
APM Level : 0080h [ON]
AAM Level : ----
Drive Letter :
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 193 186 _51 000000000175 Taux Erreur en Lecture
03 154 146 _21 000000000503 Temps moyen mise en rotation
04 100 100 __0 000000000090 Décompte des cycles de mise en rotation
05 200 200 140 000000000000 Nombre de secteurs réalloués
07 169 169 __0 0000000002B8 Taux d'erreurs d'accès des têtes
09 100 100 __0 000000000060 Heures de Fonctionnement
0A 100 100 __0 000000000000 Nombre d'essais de relancement de la rotation
0B 100 253 __0 000000000000 Nombre de recalibration
0C 100 100 __0 000000000064 Nombre total de cycles marche/arrêt du disque dur
C0 200 200 __0 000000000052 Nombre de fois que l'armature magnétique a été rétractée automatiquement suite à une coupure secteur
C1 200 200 __0 000000000595 Nombre de fois que la tête a changé de position
C2 115 _95 __0 00000000001C Température interne actuelle.
C4 200 200 __0 000000000000 Nombre d'opérations de réallocation (remap)
C5 200 200 __0 000000000003 Nombre de secteurs "instables"
C6 100 253 __0 000000000000 Nombre total d'erreurs incorrigibles d'un secteur
C7 200 200 __0 000000000000 Nombre d'erreurs dans le transfert de données via le câble d'interface
C8 100 253 __0 000000000000 Nombre total d'erreurs à l'écriture d'un secteur
-- IDENTIFY_DEVICE ---------------------------------------------------------
0 1 2 3 4 5 6 7 8 9
000: 427A 3FFF C837 0010 0000 0000 003F 0000 0000 0000 Bz?..7.......?......
010: 2020 2020 2057 442D 5758 3631 4139 3244 3431 3135 WD-WX61A92D4115
020: 0000 4000 0000 3031 2E30 3141 3031 5744 4320 5744 ..@...01.01A01WDC WD
030: 3530 3030 4C4D 5657 2D31 3143 4B52 5330 2020 2020 5000LMVW-11CKRS0
040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00 ..../.
050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB 0100 @.......?....?......
060: FFFF 0FFF 0000 0107 0003 0078 0078 0078 0078 0010 ...........x.x.x.x..
070: 0000 0000 0000 0000 0000 001F 9F06 0004 004C 0000 .................L..
080: 01FE 0000 706B 7C09 6123 7069 BC09 6123 007F 004F ....pk|.a#pi..a#...O
090: 0001 0080 BBBB 0000 0000 0000 0000 0000 0000 0000 ....................
100: 6031 3A37 0000 0000 0000 0000 6003 0000 5001 4EE2 `1:7........`...P.N.
110: 0786 0E78 0000 0000 0000 0000 0000 0000 0000 4018 ...x..............@.
120: 4018 0000 0000 0000 0000 0000 0000 0000 0021 0000 @................!..
130: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
140: 0000 0000 0004 0000 0000 0000 0000 0000 0000 0000 ....................
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
200: 0000 0000 0000 0000 0000 0000 70B5 0000 0000 4000 ............p.....@.
210: 0000 0000 0000 0000 0000 0000 0000 1518 0000 0000 ....................
220: 0000 0000 103E 0000 0000 0000 0000 0000 0000 0000 .....>..............
230: 0000 0000 0000 0000 0001 1000 0000 0000 0000 0000 ....................
240: 0000 0000 0000 4000 0000 0000 0000 0000 0000 0000 ......@.............
250: 0000 0000 0000 0000 0000 B2A5 ............
-- SMART_READ_DATA ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 10 00 01 2F 00 C1 BA 75 01 00 00 00 00 00 03 27 .../...u.......'
010: 00 9A 92 03 05 00 00 00 00 00 04 32 00 64 64 90 ...........2.dd.
020: 00 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00 .......3........
030: 00 00 07 2E 00 A9 A9 B8 02 00 00 00 00 00 09 32 ...............2
040: 00 64 64 60 00 00 00 00 00 00 0A 32 00 64 64 00 .dd`.......2.dd.
050: 00 00 00 00 00 00 0B 32 00 64 FD 00 00 00 00 00 .......2.d......
060: 00 00 0C 32 00 64 64 64 00 00 00 00 00 00 C0 32 ...2.ddd.......2
070: 00 C8 C8 52 00 00 00 00 00 00 C1 32 00 C8 C8 95 ...R.......2....
080: 05 00 00 00 00 00 C2 22 00 73 5F 1C 00 00 00 00 .......".s_.....
090: 00 00 C4 32 00 C8 C8 00 00 00 00 00 00 00 C5 32 ...2...........2
0A0: 00 C8 C8 03 00 00 00 00 00 00 C6 30 00 64 FD 00 ...........0.d..
0B0: 00 00 00 00 00 00 C7 32 00 C8 C8 00 00 00 00 00 .......2........
0C0: 00 00 C8 08 00 64 FD 00 00 00 00 00 00 00 00 00 .....d..........
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
160: 00 00 00 00 00 00 00 00 00 00 00 00 FC 21 01 7B .............!.{
170: 03 00 01 00 02 61 05 00 00 00 00 00 00 00 00 00 .....a..........
180: 00 00 01 02 00 00 00 00 00 00 00 00 00 00 00 00 ................
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7F ................
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 10 00 01 33 C8 C1 00 00 00 00 00 00 00 00 03 15 ...3............
010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 ................
020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00 ................
030: 00 00 07 00 C8 A9 00 00 00 00 00 00 00 00 09 00 ................
040: 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 ................
050: 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00 00 ................
060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 C0 00 ................
070: 00 00 00 00 00 00 00 00 00 00 C1 00 00 00 00 00 ................
080: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00 ................
090: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C5 00 ................
0A0: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00 ................
0B0: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00 ................
0C0: 00 00 C8 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C3 ................
PostPosted: January 25th, 2020, 1:38
Was the drive dropped while spinning or while turned off ?
Did ddrescue extract some data or nothing at all ?
There are no reallocated sectors, and only 3 unstable / pending sectors, so the platters themselves seem fine at this point, but this looks bad :
It's probably impossible to recover the data without replacing the head stack assembly. If ddrescue can't access the data on the platters (because of a problem with the heads) there's not much more that can be done "avec les moyens du bord"... (Except praying Joe Pesci, but it hasn't been established as an efficient data recovery procedure.)
This should have been said from the beginning to get a proper diagnostic... And of course, if the failure was caused by a shock, changing the PCB can't possibly be the cure. Besides, if the drive can still be turned on it implies that the PCB is still functional.
PostPosted: January 25th, 2020, 8:22
For the disc the person does not remember if it was or lit during the fall.
DDrescue, unfortunately, didn't recover anything.
Thank you for your diagnosis. I understand he's out.
Is there a place where I can buy reading heads because I haven't found one yet?
Thank you
PostPosted: January 25th, 2020, 8:59
In an oversimplified approach, the procedure should be:
1) SATA adaptation
2) Test heads to ensure all are good (likely they are not, therefore requiring head swap)
3) Create clone
4) Decrypt data (how to do this depends heavily on what tools you have available). Without professionals tools, and since reallymine may not support it, likely you will have to do it manually with the use of a compatible SATA to USB bridge from a compatible My Book model external drive.
Lacking advanced tools, compatible parts and experience. It will likely be a very challenging recovery to learn from.
PostPosted: January 26th, 2020, 2:22
Professionals take matching heads from so called "donor" drives known to be compatible. (They keep many in store from various brands / models to be ready for as many jobs as possible, and for the remainder they must have dedicated providers... or sometimes for rare and old / odd models they resort to asking other companies if by any chance they have one in the depths of their inventories... sometimes it's so rare that the owner has to search a matching unit on eBay or something...)
As has been said above, with your current knowledge level, your current skill set and your current equipment, the chances of a successful recovery are about as good as the chances of a thousand monkeys typing on a thousand keyboards while seating in a sauna set to maximum temperature with no food or water to re-write Les Misérables before they all die from thirst and exhaustion.
So the owner has to decide if the drive's contents are worth about 600€ to get it done in a specialized data recovery company nearby, or if it is not (which means for instance that pictures collected over a 5 years period are not worth 10€ / month) then start the grieving process and let it go. Or perhaps someone here may propose you a significantly cheaper fee, but then there's the risk of shipping a HDD with unique content abroad. (I had such a proposal once after requesting a diagnostic on behalf of someone, in a similar situation, the owner decided against it and preferred to save money until she has enough to pay for an advanced recovery service without making a dent in the budget. Because, in its current state, if it's not tampered with any further, the drive's condition should not degrade, it can wait a few months definitely and a few years almost certainly if money is an issue right now. Unless the "stuff on it" is necessary now, for work or studies, in which case she could borrow 100€ from six good friends and repay them later on when she has succeeded in her endeavours...)
Shouldn't work with the original bridge ?
PostPosted: January 26th, 2020, 8:54
Hello
thank you for your response.
Well if I understand well 2 possible solutions either it is necessary to call upon a professional and the not possible no budget, or I have fun with the hard disk and form at the same time.
So I take the solution 2, the hard drive is a WD "WD5000LMVW" I searched on the internet, but impossible to find another one at a reasonable price for me.
so is it to use a WD5000LPLX as a base.
Thank you for your feedback
PostPosted: January 26th, 2020, 13:46
It would if we had a compatible healthy drive that would work with the patient's PCB to use as a cloning destination drive.
Since finding a drive like that is very expensive or hard to find, then have to implement the other solution.
Users browsing this forum: No registered users and 42 guests
