 Post subject: In case...
PostPosted: January 29th, 2020, 12:21
Working on Charger 2TB.
All sectors shows zero.
What if 190 is corrupted (trying to fix) ? ( all other mods. are intact 31, 33, 189...etc )
Is there a way to workaround ?
Thanks for any suggestions.
 Post subject: Re: In case...
PostPosted: January 29th, 2020, 12:29
could be heads :idea:
Data Recovery Pakistan
PostPosted: January 29th, 2020, 12:37
Thanks for reply, bro.
Heads tested OK (4 heads)
Reading with full speed, but all sectors shows zero.
PostPosted: January 29th, 2020, 13:05
you're attached to another object by an incline plane wrapped helically around an axis
PostPosted: January 29th, 2020, 13:27
So,
There's no way around but fixing corruption in mod 190, am I get it right?
PostPosted: January 29th, 2020, 13:37
it depends on how it is corrupted
can you send me the complete fw dump?
PostPosted: January 29th, 2020, 14:36
Sure, thanks for trying to help.
The drive takes approx. 17 seconds to reach ready.
Here we go:
New.7z [10.02 MiB]
Downloaded 358 times
PostPosted: January 29th, 2020, 15:15
the 2nd translator looks like initialized, so there is no chance to recover structured data from this thing.
Btw, the name 'new' suggests there may be an 'old' version, which might be in a better shape?
PostPosted: January 29th, 2020, 16:25
unknown wrote:
So,
if it's re-inited then yes
and it looks like re-inited
PostPosted: January 29th, 2020, 17:45
Can it be that module 190 starts only without doing any technical operation on the hard disk?
PostPosted: January 29th, 2020, 18:02
Have you tried searching for a trace of the module 0x190 in all the tracks of the SA?
PostPosted: January 29th, 2020, 18:34
Doomer wrote:
unknown wrote:
So,
That's what I wanted to confirm.
The drive was in Saudi Arabia and I believe it's already messed up.
@ Mr. Pepe : the 'new' is not suggests that there's an 'old'. (MRT not linked with DB so I created new folder and named it 'new')
In theory: is it possible to generate the second translator from 31 or 33 ?
Why 190 is 98 MB? :)
Thanks for trying to help Mr. Pepe and Mr. Doomer
PostPosted: January 30th, 2020, 4:32
no, 190 is not related to the old translator modules.
i have ideas to recover some data in suchlike situations, but it is not yet researched completely, moreover the data would not be like it was before.
PostPosted: January 30th, 2020, 9:55
Something related to building 190 from scratch and doing raw recovery without folder structure?
Some one told me that Ace trying to make something like simulated translator or virtual in cases like this and doing raw recovery in DE, is that true/possible?
PostPosted: January 30th, 2020, 10:28
yep, that was my idea. No time to implement it at the moment. I also suspect it can be done in different ways.
PostPosted: January 30th, 2020, 10:34
Thanks for the info Mr. Pepe.
Appreciate your help.
PostPosted: January 31st, 2020, 4:52
Request original SA from Saudi Arabia DR company, their representative is here on forum aswell.
Angel Data Recovery
PostPosted: January 31st, 2020, 5:27
In the first I misdiagnosis the drive behavior, the drive was spin up without heads moving then spin down ( typical issue of pre-amp failure )
When I opened the case I realized that someone has already remove heads contacts deliberately.
I believe it's not a famous company.
So, it's the costumer problem with that person and I told him the whole truth.
PostPosted: February 2nd, 2020, 10:30
Simple format may reinitialize the translator and zero fill all sectors ?
PostPosted: February 2nd, 2020, 12:25
Yes. "Simple" or "quick" format will give you a drive full of zeros
Digitalsupport Data Recovery
https://digitalsupport.dk
Users browsing this forum: No registered users and 78 guests
