 Post subject: WD10TMVV-11TK7S2 compatible drive
PostPosted: February 10th, 2020, 2:33
Does anyone know what is this drive compatible to? (WD10TMVV-11TK7S2), the head is damage, i need a compatible heads, i cant seems to find this drive.
 Post subject: Re: WD10TMVV-11TK7S2 compatible drive
PostPosted: February 10th, 2020, 5:33
It's Helios.
You can use ZSMS drive if you can't find TK7.
PostPosted: February 10th, 2020, 12:55
In my experience almost all Helios are compatible :
WD10TMVV-11TK7S1
WD10TMVW-11ZSMS0
WD10TMVW-11ZSMS1
WD10TMVW-11ZSMS4
WD10TMVW-11ZSMS5
With PCBs :
1820 - 1692 - 1814 - 1737 - 1761...etc
PostPosted: February 10th, 2020, 14:41
WD10TMVV-11TK7S1
WD10TMVW-11ZSMS0
WD10TMVW-11ZSMS1
WD10TMVW-11ZSMS4
WD10TMVW-11ZSMS5
With PCBs :
Yes, they’re quite forgiving usually.
PostPosted: February 10th, 2020, 21:14
Thank you so much guys :good:
PostPosted: February 11th, 2020, 16:54
northwind wrote:
It's Helios.
What about U4RT (example WD10TPVT-00U4RT1) ?
Is this compatible for head swap?
As i know also Shasta-3D are compatible with Helios family for head swap.
My firmware database:
PostPosted: February 12th, 2020, 3:35
bg7s(Shasta 3d) compatible with tk7s(Helios)
PostPosted: February 12th, 2020, 6:00
Yep, Shasta3D is compatible with Helios.
PostPosted: February 12th, 2020, 11:35
What's interesting is that very different slider patterns seem to work regardless . . .
http://www.datasaversllc.com
Users browsing this forum: Majestic-12 [Bot] and 247 guests
