 Post subject: WD10SPZX-24Z10T0 failed to get ROM info
PostPosted: February 12th, 2020, 19:07
Hello friends.
I have here a Palmer WD10SPZX that doesn't read ROM at all. MRT can ID it, and I even have User Sectors access, but it is very slow. When I try to Close SA access I get this:
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 2
Head map : .....................................: 0
SA Cyl Count : .................................: 512
Serials Mark : .................................: 0xFE16
Control version : ..............................: 5460
Zone allocation table : ........................: OK
SA SPT : .......................................: 1944
ROM:
Read Rom Infos : ...............................: Err
ROM Modules:
Flash ROM dir reading : ........................: Err
Read 0A module : ...............................: Err
Load SA translator : ...........................: Err
SA Module Dir Loading...
Load SA Module dir : ...........................: Error, suggest to load from the file
Configuration reading : ........................: Err
Close SA access ...
Get SA access information : ....................: Failed
Don't know what I should try to solve slow responding problem.
Data is not important, only learning proposes.
Thank you for any help.
 Post subject: Re: WD10SPZX-24Z10T0 failed to get ROM info
PostPosted: February 13th, 2020, 5:29
parmindo wrote:
Hello friends.
RAM:
ROM:
ROM Modules:
Close SA access ...
Firmware locked drive, you have to use Unlocked PCB
SlowResp solution wont work either, problem elsewhere.
Angel Data Recovery
PostPosted: February 13th, 2020, 6:07
i can probably circumvent the slow problem, but it can be several things, including weak heads. It needs to be properly diagnosed and yeah, won't work without an unlocked pcb.
PostPosted: February 13th, 2020, 7:33
Thank you guys for the replies.
I'll try to get one unlocked PCB later, since this is not a real case.
Thank you so much.
Users browsing this forum: No registered users and 251 guests
