 Post subject: MQ01UBD100
PostPosted: March 3rd, 2020, 5:45
Hi guys, I need some help...
I want to recover data from MQ01UBD100 (heads banging/ clicking) and it's G003250A. I have replaced the head from donor drive MQ01ABD075 (G003138A) but the new head is still making sound and doesn't recognise. I then put the head back in donor drive and it starting clicking there as well.
May I know if replacing head only won't be a solution? or am I missing any other step here?
Thank you in advance
 Post subject: Re: MQ01UBD100
PostPosted: March 4th, 2020, 4:43
Hi!
Maybe you damaged donor head while you replaced, or there are some media damage on patient platter.
Have you checked patient-donor heads under microscope?
PostPosted: March 4th, 2020, 11:07
your donor is not good match. its better to use same model donor head
Users browsing this forum: Google [Bot] and 127 guests
