 Post subject: ST500LM021
PostPosted: March 30th, 2020, 10:17
Hello
Drive in topic makes a strange behavior, image at high speed ( ~100 MB ) approx. 260000 sectors and after that read error approx. 260000, and so on till the rest of the drive.
any suggestions ?
Thanks in advance
 Post subject: Re: ST500LM021
PostPosted: March 30th, 2020, 15:52
Simple. one of its heads is weak.
PostPosted: March 30th, 2020, 16:12
I wish it was that easy. :)
Heads tested on donor drive and working perfectly.
PostPosted: March 30th, 2020, 16:33
build hm in DE and verify. You might find it head related...
If so, tune adaptives or try another head set.
PostPosted: March 30th, 2020, 16:55
Already tried all of that, sir.
And tried to tune adaptives for both heads separated but no luck.
Sorry for the bad quality of picture.
I think that some one has already messed with trans, am I right?
Thanks for your inputs, sir.
PostPosted: March 30th, 2020, 20:03
pls tell me if the unreadable areas are located on the same head...
PostPosted: March 30th, 2020, 20:33
Unfortunately, on both sides (0,1).
Two sides make the same behavior.
I believe it's a defect list/s and/or trans problem.
PostPosted: March 31st, 2020, 5:43
it would be very hard to produce such problem with the translator. In case of a translator corruption You have either no LBA access at all or you have partial access up to a specific LBA but not such intermittent access you described.
PostPosted: March 31st, 2020, 6:30
First sectors and last sectors are readable so there's complete LBA access.
This is very odd, first time see such case.
Thanks for trying to help.
PostPosted: March 31st, 2020, 8:52
the head map built by DE might be shifted due to MC. Thus you get the illusion that the unreadable areas are on both heads but in fact they are not.
Users browsing this forum: No registered users and 314 guests
