 Post subject: ST2000DM001 Head Test Result
PostPosted: February 27th, 2020, 8:55
Hi
Apart from any other problems this drive has would this result show weak heads?
F3 7>X
Head 00 Resistance 0113
Head 01 Resistance 0047
Head 02 Resistance 0116
Head 03 Resistance 0164
F3 7>
Head 01 is that one all but dead?
 Post subject: Re: ST2000DM001 Head Test Result
PostPosted: February 27th, 2020, 9:23
Do the heads read when you clone?
PostPosted: February 27th, 2020, 9:43
Thanks for the reply.
I can only clone the first 0.7% at normal speed then it is VERY slow after then but reads without errors.
Is a little slow to come ready but not too bad.
Smart is showing many bad sectors.
Drive does not make clicking noises
PostPosted: February 27th, 2020, 11:12
If you disable head 1 while imaging, do the other 3 heads read at full speed for the remainder of the drive? It is not uncommon for 1 head, particularly head 1, to only read a small portion of lower LBAs on the Seagate DM series drives. A head change usually results in a finishing the clone at full speed. But, I'd get the other 3 heads first, if they are reading fine, just in case the head change doesn't go as smoothly as one would hope.
PostPosted: February 27th, 2020, 14:28
dick wrote:
Hi
F3 7>X
F3 7>
can you also test heads against Zones:
/2T880
post output here
Data Recovery Pakistan
PostPosted: February 27th, 2020, 15:24
MindMergepk wrote:
dick wrote:
Hi
F3 7>X
F3 7>
/2T880
post output here
Hi and thanks. Here is the output:
C!(k0x40MC!¨ë‹0x40M
Spin Up
Trans.
Spin Up
SpinOK
TCC:0015
(P) SATA Reset
ASCII Diag mode
F3 T>/7
F3 7>
ASCII Diag mode
F3 T>/2T880
WARNING: Drive MC Area has been modified by serial port.
MC area must be re-initialized to ensure MC control data is valid
DO NOT SHIP WITHOUT FIRST RE-INITIALIZE MC AREA!
Cyl Head MnZn Throughput CalThruput
Hd Zn Skew Skew Skew (MB/s) (MB/s) Ratio StartLBA EndLBA
0 00 19 6E 69 185.899 188.086 0.988 000000000000 000000000CA0
0 01 19 6E 69 203.393 205.777 0.988 0000003C61C3 0000003C6F93
0 02 19 6E 69 208.918 211.364 0.988 00000201D9BE 00000201E7EE
0 03 19 6E 69 197.428 199.725 0.988 0000039446EC 000003945454
0 04 19 6E 69 194.203 196.466 0.988 000004FAC511 000004FAD241
0 05 19 6E 69 194.658 196.932 0.988 00000664334D 000006644085
0 06 19 6E 69 193.272 195.535 0.988 000007C18936 000007C19656
0 07 19 6E 69 190.527 192.741 0.988 000009174DDF 000009175ACF
0 08 19 6E 69 190.987 193.207 0.988 00000A1EA7AB 00000A1EB4A3
0 09 19 6E 69 185.915 188.086 0.988 00000B398E4D 00000B399AED
0 0A 19 6E 69 182.236 184.361 0.988 00000CC6608E 00000CC66CEE
0 0B 19 6E 69 180.397 182.499 0.988 00000DD6A47A 00000DD6B0BA
0 0C 19 6E 69 176.706 178.775 0.988 00000ED858CB 00000ED864CB
0 0D 19 6E 69 173.032 175.050 0.988 00000FDD2CD1 00000FDD3891
0 0E 19 6E 69 168.902 170.860 0.988 000010DE0EAF 000010DE1A27
0 0F 19 6E 69 164.760 166.670 0.988 000011D423BF 000011D42EEF
0 10 19 6E 69 160.140 162.015 0.988 000012D41E3B 000012D4291B
0 11 19 6E 69 156.024 157.824 0.988 000013C9BA91 000013C9C529
0 12 19 6E 69 151.411 153.169 0.988 000014B56288 000014B56CD0
0 13 19 6E 69 148.186 149.910 0.988 0000157B6DBA 0000157B77CA
0 14 19 6E 69 141.747 143.392 0.988 0000166538F0 000016654290
0 15 19 6E 69 137.177 138.736 0.988 00001751CA49 00001751D399
0 16 19 6E 69 133.463 135.012 0.988 0000183C3AD8 0000183C43E8
0 17 19 6E 69 127.489 128.960 0.988 000018FB7530 000018FB7DD8
0 18 19 6E 69 123.373 124.770 0.988 000019B0763D 000019B07E9D
0 19 19 6E 69 114.158 115.458 0.988 00001A9B2AB4 00001A9B3274
0 1A 19 6E 69 109.088 110.337 0.988 00001B2CC642 00001B2CCDAA
0 1B 19 6E 69 108.196 109.406 0.988 00001BC9AF17 00001BC9B66F
0 1C 19 6E 69 103.116 104.285 0.988 00001C63BAFF 00001C63C1FF
0 1D 19 6E 69 99.422 100.561 0.988 00001CD4AD7B 00001CD4B43B
1 00 19 6E 69 0.000 100.561 0.000 000000003AD4 000000002FEC invalid address
1 01 19 6E 69 0.000 100.561 0.000 0000003CA467 0000003C978F invalid address
1 02 19 6E 69 0.000 100.561 0.000 000002021CDA 000002021032 invalid address
1 03 19 6E 69 0.000 100.561 0.000 0000039487EC 000003947B54 invalid address
1 04 19 6E 69 0.000 100.561 0.000 000004FB04A9 000004FAF869 invalid address
1 05 19 6E 69 0.000 100.561 0.000 0000066471CD 000006646605 invalid address
1 06 19 6E 69 0.000 100.561 0.000 000007C1C7DE 000007C1BBEE invalid address
1 07 19 6E 69 0.000 100.561 0.000 000009178BFB 000009178013 invalid address
1 08 19 6E 69 0.000 100.561 0.000 00000A1EE513 00000A1ED97B invalid address
1 09 19 6E 69 0.000 100.561 0.000 00000B39C9C1 00000B39BE99 invalid address
1 0A 19 6E 69 0.000 100.561 0.000 00000CC69BC6 00000CC69076 invalid address
1 0B 19 6E 69 0.000 100.561 0.000 00000DD6DE86 00000DD6D38E invalid address
1 0C 19 6E 69 0.000 100.561 0.000 00000ED89197 00000ED886DF invalid address
1 0D 19 6E 69 0.000 100.561 0.000 00000FDD654D 00000FDD5A75 invalid address
1 0E 19 6E 69 0.000 100.561 0.000 000010DE454B 000010DE3AEB invalid address
1 0F 19 6E 69 0.000 100.561 0.000 000011D458F3 000011D44EDB invalid address
1 10 19 6E 69 0.000 100.561 0.000 000012D451B7 000012D447FF invalid address
1 11 19 6E 69 0.000 100.561 0.000 000013C9ED31 000013C9E389 invalid address
1 12 19 6E 69 0.000 100.561 0.000 000014B593C0 000014B58A58 invalid address
1 13 19 6E 69 0.000 100.561 0.000 0000157B9D9E 0000157B9486 invalid address
1 14 19 6E 69 0.000 100.561 0.000 000016656730 000016655E50 invalid address
1 15 19 6E 69 0.000 100.561 0.000 00001751F6A9 00001751EE39 invalid address
1 16 19 6E 69 0.000 100.561 0.000 0000183C64F4 0000183C5D2C invalid address
1 17 19 6E 69 0.000 100.561 0.000 000018FB9E48 000018FB9680 invalid address
1 18 19 6E 69 0.000 100.561 0.000 000019B09CB9 000019B09549 invalid address
1 19 19 6E 69 0.000 100.561 0.000 00001A9B4EC4 00001A9B47B4 invalid address
1 1A 19 6E 69 0.000 100.561 0.000 00001B2CE91D 00001B2CE235 invalid address
1 1B 19 6E 69 0.000 100.561 0.000 00001BC9D118 00001BC9CA78 invalid address
1 1C 19 6E 69 0.000 100.561 0.000 00001C63DB0F 00001C63D48F invalid address
1 1D 19 6E 69 0.000 100.561 0.000 00001CD4CC81 00001CD4C631 invalid address
2 00 19 6E 69 200.643 202.984 0.988 000000003C31 0000000049D1
2 01 19 6E 69 224.104 226.727 0.988 0000003CA602 0000003CB53A
2 02 19 6E 69 220.870 223.468 0.988 000002021E6F 000002022D6F
2 03 19 6E 69 217.667 220.210 0.988 00000394897F 000003949847
2 04 19 6E 69 213.983 216.485 0.988 000004FB0631 000004FB14B9
2 05 19 6E 69 210.319 212.761 0.988 000006647346 00000664818E
2 06 19 6E 69 204.336 206.708 0.988 000007C1C95C 000007C1D73C
2 07 19 6E 69 203.402 205.777 0.988 000009178D78 000009179B48
2 08 19 6E 69 200.169 202.518 0.988 00000A1EE686 00000A1EF41E
2 09 19 6E 69 194.669 196.932 0.988 00000B39CB26 00000B39D85E
2 0A 19 6E 69 192.828 195.069 0.988 00000CC69D30 00000CC6AA48
2 0B 19 6E 69 187.308 189.483 0.988 00000DD6DFE5 00000DD6EC9D
2 0C 19 6E 69 186.838 189.017 0.988 00000ED892EE 00000ED89F9E
2 0D 19 6E 69 181.331 183.430 0.988 00000FDD66A8 00000FDD72F8
2 0E 19 6E 69 180.395 182.499 0.988 000010DE4697 000010DE52D7
2 0F 19 6E 69 175.808 177.844 0.988 000011D45A36 000011D46626
2 10 19 6E 69 171.179 173.188 0.988 000012D452EE 000012D45E8E
2 11 19 6E 69 166.615 168.532 0.988 000013C9EE66 000013C9F9B6
2 12 19 6E 69 161.550 163.411 0.988 000014B594ED 000014B59FE5
2 13 19 6E 69 156.465 158.290 0.988 0000157B9EC1 0000157BA961
2 14 19 6E 69 152.338 154.100 0.988 00001665684C 0000166572A4
2 15 19 6E 69 147.730 149.444 0.988 00001751F7B7 0000175201BF
2 16 19 6E 69 142.673 144.323 0.988 0000183C65ED 0000183C6F9D
2 17 19 6E 69 136.236 137.805 0.988 000018FB9F41 000018FBA881
2 18 19 6E 69 130.256 131.753 0.988 000019B09DA7 000019B0A67F
2 19 19 6E 69 124.281 125.701 0.988 00001A9B4FA6 00001A9B5816
2 1A 19 6E 69 114.146 115.458 0.988 00001B2CE9FA 00001B2CF1BA
2 1B 19 6E 69 112.772 114.062 0.988 00001BC9D1EC 00001BC9D994
2 1C 19 6E 69 107.257 108.475 0.988 00001C63DBDF 00001C63E327
2 1D 19 6E 69 103.565 104.751 0.988 00001CD4CD4B 00001CD4D453
3 00 19 6E 69 0.000 104.751 0.000 0000000079DE 000000006D86 invalid address
3 01 19 6E 69 0.000 104.751 0.000 0000003CECF6 0000003CDE4E invalid address
3 02 19 6E 69 0.000 104.751 0.000 000002026459 0000020255E9 invalid address
3 03 19 6E 69 0.000 104.751 0.000 00000394CEBE 00000394C05E invalid address
3 04 19 6E 69 0.000 104.751 0.000 000004FB49F4 000004FB3BF4 invalid address
3 05 19 6E 69 0.000 104.751 0.000 00000664B5EC 00000664A824 invalid address
3 06 19 6E 69 0.000 104.751 0.000 000007C20AAC 000007C1FD0C invalid address
3 07 19 6E 69 0.000 104.751 0.000 00000917CE30 00000917C0C0 invalid address
3 08 19 6E 69 0.000 104.751 0.000 00000A1F2621 00000A1F18F1 invalid address
3 09 19 6E 69 0.000 104.751 0.000 00000B3A08D3 00000B39FC13 invalid address
3 0A 19 6E 69 0.000 104.751 0.000 00000CC6D9F9 00000CC6CD79 invalid address
3 0B 19 6E 69 0.000 104.751 0.000 00000DD71B32 00000DD70EF2 invalid address
3 0C 19 6E 69 0.000 104.751 0.000 00000ED8CD90 00000ED8C190 invalid address
3 0D 19 6E 69 0.000 104.751 0.000 00000FDD9FCE 00000FDD940E invalid address
3 0E 19 6E 69 0.000 104.751 0.000 000010DE7EEC 000010DE7374 invalid address
3 0F 19 6E 69 0.000 104.751 0.000 000011D49122 000011D485F2 invalid address
3 10 19 6E 69 0.000 104.751 0.000 000012D488AA 000012D47DAA invalid address
3 11 19 6E 69 0.000 104.751 0.000 000013CA226D 000013CA17D5 invalid address
3 12 19 6E 69 0.000 104.751 0.000 000014B5C79E 000014B5BD3E invalid address
3 13 19 6E 69 0.000 104.751 0.000 0000157BCFE3 0000157BC5D3 invalid address
3 14 19 6E 69 0.000 104.751 0.000 0000166597F2 000016658E3A invalid address
3 15 19 6E 69 0.000 104.751 0.000 0000175225E1 000017521C79 invalid address
3 16 19 6E 69 0.000 104.751 0.000 0000183C9275 0000183C8965 invalid address
3 17 19 6E 69 0.000 104.751 0.000 000018FBCA01 000018FBC141 invalid address
3 18 19 6E 69 0.000 104.751 0.000 000019B0C68C 000019B0BE2C invalid address
3 19 19 6E 69 0.000 104.751 0.000 00001A9B7618 00001A9B6E58 invalid address
3 1A 19 6E 69 0.000 104.751 0.000 00001B2D0C92 00001B2D04F2 invalid address
3 1B 19 6E 69 0.000 104.751 0.000 00001BC9F3AC 00001BC9EC54 invalid address
3 1C 19 6E 69 0.000 104.751 0.000 00001C63FC01 00001C63F501 invalid address
3 1D 19 6E 69 0.000 104.751 0.000 00001CD4EC83 00001CD4E5AB invalid address
F3 2>
PostPosted: February 27th, 2020, 15:54
u have MRT or SEDIV ? there is work around to make Head 1 reading better
PostPosted: February 28th, 2020, 7:07
No I don't have any suitable tools.
It looks like the drive will have to go to our regular pro.
PostPosted: February 28th, 2020, 9:13
that is good decision.
PostPosted: February 28th, 2020, 13:56
I wonder how to do with MRT
Sexy Womans from your town
Users browsing this forum: Google [Bot] and 47 guests
