 Post subject: WDC WD7500AADS-00M2B0 Wrong size detected
PostPosted: March 30th, 2020, 7:32
Hi I have a WDC WD7500AADS-00M2B0 I stored a long time with data on it, I hadn't noticed when I had been given this drive that a 465GB partition was on it.
Now I've copied data and cleaned disk with diskpart, I sadly discovered even after cleaning the full size is 465GB as if the partition has somehow modified firmware info.
please look at HDD sentinel data:
The disc if fully healty, works fine but the capacity is reduced. Is there any way to fix it? Firmware update or reflash?
Thanks in advance,
 Post subject: Re: WDC WD7500AADS-00M2B0 Wrong size detected
PostPosted: March 30th, 2020, 17:53
Well,
Seems As If HPA is Set in SA of this HDDD
PostPosted: March 30th, 2020, 17:56
Thank you for your reply, is there any way to fix this?
PostPosted: March 30th, 2020, 18:02
HDAT2 can remove the HPA, as can MHDD, HDD Capacity Restore Tool, hdparm, SeaTools.
Users browsing this forum: No registered users and 245 guests
