 Post subject: Western Digital 1TB drive with 7488 bad sectors
PostPosted: April 13th, 2020, 20:24
Hi guys
I have a WD with 7488 bad sectors. I know it needs replacing, but I want to get my files from it without needing to wait for two years.
Any ideas?
 Post subject: Re: Western Digital 1TB drive with 7488 bad sectors
PostPosted: April 13th, 2020, 21:22
If you are prepared to risk your data, apply the "slow fix" with HDDSuperTool and then clone the drive with HDDSuperClone.
http://www.sdcomputingservice.com
PostPosted: April 13th, 2020, 22:07
What if I'm not prepared to risk my data? Professional job?
PostPosted: April 14th, 2020, 6:09
Yes.
Contact member pcimage here http://pcimage.co.uk/contact-us/
They're in Peterborough and will help you out.
PostPosted: April 14th, 2020, 13:39
Should be reasonably straightforward (at the moment) with the right professional equipment and not too expensive, if you’d like to send it in! :-)
PostPosted: April 15th, 2020, 15:00
I've sent PCImage work in the past and they are very good, so you don't need to worry on that score..
Users browsing this forum: No registered users and 211 guests
