 Post subject: WD5000BMVW-11S5XS0
PostPosted: April 20th, 2020, 17:30
Hello
I am stucking with the drive in topic.
I have tried close matched donors without any luck. ( close DCM, close Date and close ROM ver )
I always having problems with matching donors with this drive in particular.
FB and FBLite are very forgiving with each other as a donors, except that puppy.
ROM ver 003003V
Thanks for any suggestions
 Post subject: Re: WD5000BMVW-11S5XS0
PostPosted: April 21st, 2020, 5:08
What is the question? Looking to change heads?
PostPosted: April 21st, 2020, 5:14
The question is what is the exact parameters should I match for a perfect compatible donor for this particular drive for changing heads?
Thanks for your input.
PostPosted: April 21st, 2020, 7:45
As always, preamp and heads count
PostPosted: April 21st, 2020, 8:25
head type is not less important.
PostPosted: April 21st, 2020, 8:52
The only Issue I face with this model Head swap is the physical Heads count , it always changed from device to another . i mean it may be 012 or 013 or even 023 , so i prefer to take 1 tb donor for this 500
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: April 21st, 2020, 9:06
Head map is : 1,2,3
All donors I have are 4 heads (1 TB )
Some donors makes the drive clicking and others makes the drive busy for a while then ready without any SA access even with matched ldr.
I have worked with a similar drive 2 years ago and didn't remember if I figured this issue out or not. :)
PostPosted: April 27th, 2020, 21:33
check Drive serial number first 3 characters & DCM thats enough ...
Good Luck.
PostPosted: May 1st, 2020, 12:31
Matching preamp type for this particular drive is really PITA.
As I searched all over the forum and found that many people have a compatibility problem with the same drive.
PostPosted: May 1st, 2020, 12:40
ROM ver 003003V
Firebird and FBlite are not cross compatible, never worked for me
Data Recovery Pakistan
PostPosted: May 1st, 2020, 12:55
they are.
PostPosted: May 1st, 2020, 17:14
pepe wrote:
they are.
PostPosted: May 1st, 2020, 17:20
pepe wrote:
they are.
you are both correct :)
PostPosted: May 10th, 2020, 6:01
I have found a perfect donor, but head map is 0,1,2 and the patient is 1,2,3. :lol:
I know that I am not lucky enough
PostPosted: May 11th, 2020, 17:43
At least I have got side 1 and 2 :D
Waiting for another donor to complete 3
In theory I think it is possible to flip the top platter and read side 3 with head 2?
PostPosted: May 11th, 2020, 19:40
Nope. The data would be streaming backwards.
PostPosted: May 13th, 2020, 6:27
I see.
Without flipping ( Top platter with the bottom platter ) ?
If we are talking about Shrek with 4 platters and we will change platter #4 with #3 ?
PostPosted: May 13th, 2020, 8:11
Re. "Top platter with the bottom platter," the top platter won't have an SA, so that won't boot. I'm not knowledgeable enough to know how zone tables are checked against address markers found on tracks, but assume they are checked. If they are, swapping platters #3 and #4 wouldn't work either.
PostPosted: May 13th, 2020, 14:33
I can do that but i think it is beyond the knowledge of many dr people.
PostPosted: May 13th, 2020, 17:30
Doing what? Swap between SA platter with none-SA platter? Or swap between two none-SA platters? Or both? :D
Thanks Mr. LarrySabo and Mr. Pepe for the valuable info.
Users browsing this forum: No registered users and 102 guests
