 Post subject: Tray that no longer rotates
PostPosted: May 14th, 2020, 3:31
Hello
I'm still testing and breaking down the hard drive to make my hand.
Today I took out an old hard drive that hasn't worked for a long time.
I looked at it and saw that the motor that drives the drives is not running. I tried just without forcing it to turn right or left and impossible.
You would say that it is what kind of failure? and what would be the solution?
Translated with www.DeepL.com/Translator (free version)
 Post subject: Re: Tray that no longer rotates
PostPosted: May 14th, 2020, 3:40
Those are the cases where a platter swap is the solution.
Or eventually replace the spindle.
ACELab partner
PostPosted: May 14th, 2020, 5:19
Thank you for your response.
Are there Tutoials to see this?
PostPosted: May 14th, 2020, 5:25
Yes. Here it is https://www.youtube.com/watch?v=rWR-bSJeLX8
Angel Data Recovery
PostPosted: May 14th, 2020, 17:55
Probably does require platter(s) transfer, but this is 100% NOT a DIY case.
Depending on actual model, this can be a moderate to extremely difficult case even for most pros!
Proper diagnosis is required.
PostPosted: May 15th, 2020, 3:14
Thank you. That's nice.
PostPosted: May 16th, 2020, 15:50
Deleted
Wrong message
Sexy Womans from your town
Users browsing this forum: No registered users and 180 guests
