Firmware for Fujitsu MHV2080BH
February 13th, 2008, 12:50
Does anyone has modules for a Fujitsu MHV2080BH.
Thanks.
Re: Firmware for Fujitsu MHV2080BH
February 14th, 2008, 5:37
PCI or UDMA ?
Dobre
February 14th, 2008, 6:43
UDMA is better.
February 14th, 2008, 9:58
here are some modules.
Dobre
FUJITSU MHV2080BH 0081002D NW70T61255LK.rar
modules 2
(155.92 KiB) Downloaded 2195 times
FUJITSU MHV2080BH 892C NW13T662AFWU.rar
modules
(159.06 KiB) Downloaded 1929 times
June 3rd, 2008, 14:48
I have FUJITSU MHV2080BH, NW13T6528WH7, Firmware: 892C.
Should I update?
What will the update do to my HD?
How do I do this? I could not find and firmware info on Fujitsu website.
Thank you!
June 5th, 2008, 12:37
Hi Dforionstar,
If u don't have problems with the drive, U probably don't need to mess with FW. If something turns out wrong, u loose the drive and the data, so it is better not to touch it.
July 18th, 2008, 1:39
My Fujitsu MHV2080BH 80gb SATA HDD on an Nc6320 HP Laptop , after 5 mins of run gives me repeated BSOD's.
I am thinking this is a problem with firmware not a physical HDD failure. Does anyone have a similar exp and some sucess.?
I download the firmware from the above thread but I dont know any TOOL or UTILTY that will help me install that very firmware. I stumbled upon and IBM install utility on this website that preloads its own firmware , but not this firmware.
Does anyone know how to install a firmware .pcr file you already have
Sam
July 18th, 2008, 3:09
Sieger,
You need the PC3K utility for that. This is a combination of hard-and software, and very expensive.
Without that these files are useless.
Best regards,
Dobre
July 18th, 2008, 14:22
Hi Friends
Thanks for your help. The BSOD's showed varying ' curses' . The most common was a kernel_in_page_error or some like that. Most common goggled cause was HDD failure. I agree with what the gentleman just said - about investing in trying to get back your data from a HDD on respirators and sending it to death. Fortunately I got back my data and the HDD is right now co-operative enough to give more than a few spins as long as I dont make it run - but soon as I copy or move even 50mb of data there is the BSOD.
I think I got it all wired wrong - that firmware could be the reason. Apparently 'firmwaring' the drive is a different ball game. So I just threw it off - and got a new one.
Thanks for all your help folks have a great week-end
Bye
Sam
September 22nd, 2010, 23:21
Thanks but What is password file .raz?
November 9th, 2010, 14:45
Thanks but What is password file FUJITSU MHV2080BH 0081002D NW70T61255LK.rar
April 25th, 2020, 15:12
I have a FUJITSU MHV2080BH with a size of 80 GB.
Is my current firmware version 892C the latest firmware?
April 27th, 2020, 2:37
AntonB wrote:I have a FUJITSU MHV2080BH with a size of 80 GB.
This is the only one! Enjoy it!
:D :D :D
April 27th, 2020, 4:22
BGman wrote:This is the only one! Enjoy it!
:D :D :D
Ok, what a pity.
Thank you
April 27th, 2020, 17:00
:D :D :D
Ok, what a pity.
Thank you
Firmware updates are generally only issued in response to problems. What problem are you having?
April 28th, 2020, 0:08
Maybe that the HDD doesn't work well with Windows 10?
April 29th, 2020, 8:23
AntonB wrote:Maybe that the HDD doesn't work well with Windows 10?
The HDD is more than 12 years old!!!!
What do you expect?
:shock: :shock: :shock:
Just buy another one.
April 29th, 2020, 9:19
Don't have money
