 Post subject: WD10SMZW-34Y0TS0 SED locked error
PostPosted: May 12th, 2020, 0:56
WD10SMZW-34Y0TS0 with SED locked error, i can't get access to the data or build headmap. Is there any solution to this drive with SED locked?
or i have to get a compatible unlocked pcb for it? (PCB 800066 SATA)
Thank you
 Post subject: Re: WD10SMZW-34Y0TS0 SED locked error
PostPosted: May 12th, 2020, 13:52
Yes, you need to get unlocked pcb if you want to access SA or build head map...
Users browsing this forum: Google [Bot] and 50 guests
