WD40NDZW-11MR8S0 SpyGlass 2??
June 11th, 2020, 20:43
Does anyone have any information about this family? Spyglass2?
Doesn't look like SED, SA access is clean, however the data seems encrypted somehow....
Re: WD40NDZW-11MR8S0 SpyGlass 2??
June 11th, 2020, 22:35
colanco wrote:Does anyone have any information about this family? Spyglass2?
Hi ,
Can You Upload C5 Module Of This ,If You Can find out its SA based encrypt or a sector has key ,Might be you can read that into file and provide tool a file and decrypt it
June 12th, 2020, 3:13
It's Spyglass2.
June 21st, 2020, 14:12
This is Spyglass2 family
The drive uses CPU Key as part of the data encryption process, so original PCB is a must for data recovery.
June 21st, 2020, 15:38
Doomer Sir ,
This Means We Convert Each Original PCB To SATA And Work ,Is That So :(
June 21st, 2020, 16:25
Amarbir[CDR-Labs] wrote:Doomer Sir ,
In a way, yes.
But Spyglass2 PCB is locking access to the SA (the same way as Palmer and Charger drives), so converting it to SATA is probably not the best way to recover the drive.
Imaging drive without disabling certain features (that require SA access) is dangerous and could lead to data loss.
Spyglass2 drives are truly hard nuts to crack and nightmare to work with.
June 22nd, 2020, 3:46
3 of them so far, had to work with them via USB.
Luckily, I was able to access parts of RAM and work with it to make it go faster.
June 22nd, 2020, 12:35
The particular problem here is that by native PCB (USB) there is no access to UA, by SATA full access to SA and UA but data is encrypted in UA. There is no slow problem.
June 22nd, 2020, 12:51
Conversion to SATA gives clean and full access to SA (Not SED), at least in this case.
ROM changes when changing to SATA PCB (I read about a possible modification) Discarded in this case as no exchange was made (it was reprogrammed).
SATA PCB is unlocked I haven't tried with a locked one...
June 22nd, 2020, 14:32
colanco wrote:The particular problem here is that by native PCB (USB) there is no access to UA
Why?
What's the drive behavior?
What's the initial problem?
June 22nd, 2020, 21:40
unknown wrote: Why?
I don't know, so I'm asking...
unknown wrote: What's the drive behavior?
normal operation, just like a passport with a password, although in this case it is a elements
unknown wrote: What's the initial problem?
