 Post subject: Seagate ST2000LM007 spin up but not detected
PostPosted: June 7th, 2020, 19:38
Hi everyone;
my Seagate ST2000LM007 gone instantly today. spins up nicely, no head kicking sound etc. but it is not detected in bios or several usb boxes i tested. pcb looks clean, no damage, burn etc. also all fuses and 0 ohm resistors are ok.
seagate seatool utility is crashing when i try to test that disk. also it has strange squeaky sound when i turn off the power.
any advice ?
 Post subject: Re: Seagate ST2000LM007 spin up but not detected
PostPosted: June 7th, 2020, 19:51
It's likely a firmware problem, caused by another problem: bad sectors.
Difficult to resolve without experience.
Can you post a "terminal output? If not sure what this means, then search here on the forum.
PostPosted: June 7th, 2020, 21:31
Boot 0x80M
QB
Rst 0x80M
         Srv DETCR init 0x0000
(P) SATA Reset
RAW OFF
PASS
(DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000
(MC POR Duration): 00000001A9
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
Update Mask - 000000003FE04DE8 - 00000008 - 00
Update Mask - 000000003FE04DF0 - 00000008 - 00
Update Mask - 000000003FE04DF8 - 00000008 - 00
Update Mask - 000000003FE04E00 - 00000008 - 00
Update Mask - 000000003FE04E08 - 00000008 - 00
Update Mask - 000000003FE04E10 - 00000008 - 00
Update Mask - 000000003FE04E18 - 00000008 - 00
Update Mask - 000000003FE04E20 - 00000008 - 00
Update Mask - 000000003FE04E28 - 00000008 - 00
Update Mask - 000000003FE04E30 - 00000008 - 00
Update Mask - 000000003FE04E38 - 00000008 - 00
Update Mask - 000000003FE04E40 - 00000008 - 00
Update Mask - 000000003FE04E48 - 00000008 - 00
Update Mask - 000000003FE04E50 - 00000008 - 00
Update Mask - 000000003FE04E58 - 00000008 - 00
Update Mask - 000000003FE04E60 - 00000008 - 00
Update Mask - 000000003FE04E68 - 00000008 - 00
Update Mask - 000000003FE04E70 - 00000008 - 00
Update Mask - 000000003FE04E78 - 00000008 - 00
Update Mask - 000000003FE04E80 - 00000008 - 00
Update Mask - 000000003FE04E88 - 00000008 - 00
Update Mask - 000000003FE04E90 - 00000008 - 00
Update Mask - 000000003FE04E98 - 00000008 - 00
Update Mask - 000000003FE04EA0 - 00000008 - 00
Update Mask - 000000003FE04EA8 - 00000008 - 00
Update Mask - 000000003FE04EB0 - 00000008 - 00
Update Mask - 000000003FE04EB8 - 00000008 - 00
Update Mask - 000000003FE04EC0 - 00000008 - 00
Update Mask - 000000003FE04EC8 - 00000008 - 00
Update Mask - 000000003FE04ED0 - 00000008 - 00
Update Mask - 000000003FE04ED8 - 00000008 - 00
Update Mask - 000000003FE04EE0 - 00000008 - 00
Update Mask - 000000003FE04EE8 - 00000008 - 00
Update Mask - 000000003FE04EF0 - 00000008 - 00
Update Mask - 000000003FE04EF8 - 00000008 - 00
Update Mask - 000000003FE04F00 - 00000008 - 00
Update Mask - 000000003FE04F08 - 00000008 - 00
Update Mask - 000000003FE04F10 - 00000008 - 00
Update Mask - 000000003FE04F18 - 00000008 - 00
Update Mask - 000000003FE04F20 - 00000008 - 00
Update Mask - 000000003FE04F28 - 00000008 - 00
Update Mask - 000000003FE04F30 - 00000008 - 00
Update Mask - 000000003FE04F38 - 00000008 - 00
Update Mask - 000000003FE04F40 - 00000008 - 00
Update Mask - 000000003FE04F48 - 00000008 - 00
Update Mask - 000000003FE04F50 - 00000008 - 00
Update Mask - 000000003FE04F58 - 00000008 - 00
Update Mask - 000000003FE04F60 - 00000008 - 00
Update Mask - 000000003FE04F68 - 00000008 - 00
Update Mask - 000000003FE058E0 - 00000008 - 00
Update Mask - 000000003FE058E8 - 00000008 - 00
Update Mask - 000000003FE058F0 - 00000008 - 00
Update Mask - 000000003FE058F8 - 00000008 - 00
Update Mask - 000000003FE05900 - 00000008 - 00
Update Mask - 000000003FE05908 - 00000008 - 00
Update Mask - 000000003FE05910 - 00000008 - 00
Update Mask - 000000003FE05918 - 00000008 - 00
Update Mask - 000000003FE05920 - 00000008 - 00
Update Mask - 000000003FE05928 - 00000008 - 00
Update Mask - 000000003FE05930 - 00000008 - 00
Update Mask - 000000003FE05938 - 00000008 - 00
Update Mask - 000000003FE05940 - 00000008 - 00
Update Mask - 000000003FE05948 - 00000008 - 00
Update Mask - 000000003FE05950 - 00000008 - 00
Update Mask - 000000003FE05958 - 00000008 - 00
Update Mask - 000000003FE05960 - 00000008 - 00
Update Mask - 000000003FE05968 - 00000008 - 00
Update Mask - 000000003FE05970 - 00000008 - 00
Update Mask - 000000003FE05978 - 00000008 - 00
Update Mask - 000000003FE05980 - 00000008 - 00
Update Mask - 000000003FE05988 - 00000008 - 00
Starting LBA of RW Request=0007FC09BD  Length=00000471
ProcessRWError -Read-   at LBA 0007FC0B32  Sense Code=43160080
Common path start quit now
                           ProcessRC: 00000000,00000000
                                                       SkipLen: 00000000
        ReadContinuous: 07FC09BD,00                                                     0002F6
      UnrecovSectorCount:0050,017A
                                  NumUDEs: 00000050,00000000,0000017A
        Passed: 00000080,0000012F,0000                                                     02AA
    Out:
SP Regen FAIL
SPRegen [0000|43160080] @LBA=0x07FC0B32
Setup currentretry count
                         Out:
Update Mask - 000000003FE05990 - 00000008 - 00
Harden - 07FC0B32
InitiateMarkPendingReallocateRequest for disc_lba: 0007FC0B32 CHS: 00019617.02.0175
Assert 741D - LBA 07FC0B32!
ProcessRWError -Read-   at LBA 0007FC0B33  Sense Code=43110081
                           ProcessRC: 00000001,00000000
                                                       SkipLen: 00000000
      UnrecovSectorCount:0052,017C
                                  NumUDEs: 00000052,00000000,0000017C
    Out:
SP Regen FAIL
SPRegen [0000|43160080] @LBA=0x07FC0B33
                         Out:
Update Mask - 000000003FE05998 - 00000008 - 00
Harden - 07FC0B33
InitiateMarkPendingReallocateRequest for disc_lba: 0007FC0B33 CHS: 00019617.02.0176
Assert 741D - LBA 07FC0B33!
ProcessRWError -Read-   at LBA 0007FC0B34  Sense Code=43160080
                                                       SkipLen: 00000000
        ReadContinuous: 07FC09BD,000002F6
        Un
                                  Passed: 00000080,0000012F,000002AA
        Out:
SP Regen FAIL
SPRegen [0000|43160080] @LBA=0x07FC0B34
                         Out:
Update Mask - 000000003FE059A0 - 00000008 - 00
Harden - 07FC0B34
InitiateMarkPendingReallocateRequest for disc_lba: 0007FC0B34 CHS: 00019617.02.0177
Assert 741D - LBA 07FC0B34!
ProcessRWError -Read-   at LBA 0007FC0B35  Sense Code=43110081
                                                       SkipLen: 00000000
        Un                                             ecovSectorCount:0050,017A
        Out:
PostPosted: June 7th, 2020, 22:31
Indeed, bad sectors. With accumulation of bad sectors, there are media cache and possible other issues.
PostPosted: June 8th, 2020, 7:22
i saved all data from that disk, thanks for helping.
somehow disk worked fine for a while and i copied all important information.
PostPosted: June 14th, 2020, 11:57
Hello My Friend....
Please help me out...i have similar issue with my external Seagate HDD st1000lm024....spinning okay...but did not detect under Bios and Explorere....windows disk management.
Kindly guide me...
Thanks in advance.
Users browsing this forum: No registered users and 187 guests
