 Post subject: Operation terminated
PostPosted: June 8th, 2020, 12:46
I'm receiving an error that prevents an 8 gb file from being copied to a new 500 gb hard drive I just got.
 Post subject: Re: Operation terminated
PostPosted: June 8th, 2020, 13:16
I recommend getting the free version of HardDisk Sentinal, tree climb via Disk, Surface Test, choose the HDD, Read Test -- DiskRepair (read test with sector repair). It will take some time! I think any marginal and going-bad sectors will be locked out. Upon completion, probably after all Star Wars have been watched, you can do a Windows Restart.
Try the copy operation again, please report back with your results.
The quick tests are ok too, however, such probably will not lock out marginal or going-bad sectors. Check with Arch, he knows this stuff better than I do.
"Take care of thy backups and thy restores shall take care of thee." Ben Franklin revisited
PostPosted: June 8th, 2020, 13:51
This is what I got upon launch
PostPosted: June 8th, 2020, 13:53
Unfortunately, when I follow the prompts you gave, I am asked to register for 30
PostPosted: June 8th, 2020, 16:35
I do not advice repair before data backed up. Problem could grow .
"Roadkils Unstoppable coppier" free small and capable to get files even has bad sectors.
Sexy Womans from your town
PostPosted: June 9th, 2020, 3:18
The OP was advised to test the target, not the source.
PostPosted: June 9th, 2020, 3:25
I seem to remember the problem in the first post can be caused by using Windows 10 64 bit os. If that is the case here?
I would just use any free version of Dmde to do the same job.
PostPosted: June 9th, 2020, 8:15
Upfront admission- I have the pay-for license package for HardDisk Sentinal, I did not know the free version's deep tests required registration and/or pay-for license. Maybe Arch could give us more information as to how deep will the free HDS go?
PostPosted: June 11th, 2020, 14:21
I am using Windows 10
Users browsing this forum: No registered users and 77 guests
