 Post subject: U14 EEPROM
PostPosted: August 18th, 2020, 7:49
Hi.
Pardon my newbie question as I am not a HDD master like the rest of you.
But how would I read the EEPROM?
Just show the usb-hdd into a linux machine and do an epic hacker montage or do I need some special tools?
Any gently nudge in the right direction would be appriciated.
/gorgaroth
 Post subject: Re: U14 EEPROM
PostPosted: August 18th, 2020, 8:26
if it is a SPI Flash, then you should be able to read it with FlashcatUSB. I have a few different versions of this and have read a number of different chips. Look for chip part number support down the page
https://www.embeddedcomputers.net/products/FlashcatUSB/
PostPosted: August 18th, 2020, 9:20
I thought I had pressed submit but guess I was wrong..
Summary from not submitted post:
A: Thanked you for quick reply and technical.
B: Refference to the matrix about taking the red pill and seeing how deep the rabbithole goes but that I was unable to see anything that looked like the drive on the page you sent.
C: That the drive in question was a My Passport Essential 1058:07a8 INIC-3608
So.. Any other words of wisdom for me on my journey to read the Eeprom?
/gorgaroth
PostPosted: August 18th, 2020, 14:20
I would avoid those tools. They are unsuitable for 2.5V and 1.8V devices.
3.3v and 5v memory devices
PostPosted: August 18th, 2020, 22:52
The different models have a wide range of support, some overlap between them, but also some uniqeness as well.
https://www.embeddedcomputers.net/products/FlashcatUSB_Mach1/
Hardware Features and Compatability:
ARM 32-bit processor with HS USB (480 Mbit/s)
FPGA co-processor with 4000 logic elements
Multi-voltage supported: 1.8V and 3V
NAND / NOR memory supported up to 256-gbit
Data I/O: 8X/16X and DQS supported
ECC supported: Hamming, RS and BHC
SPI and SQI Flash supported
Cypress HyperFlash S26KS/KL memory supported
Users browsing this forum: Google [Bot] and 41 guests
