 Post subject: Strange disk failure WD2500BEVT
PostPosted: September 1st, 2020, 6:33
Hi all.
I've been reading the forum for a long time but so far I haven't registered. But now I have a similar case of the thread op.
I have a WD2500BEVT unit that has a bad PCB, (the MCU chip was physically broken). Buy the PCB that corresponds to you. Before moving the U12 chip from the damaged PCB I wanted to first test the donor PCB to see if it starts the motor, in this aspect I start the motor but as we all know it clicks of dead in the absence of changing the u12 chip to the new PCB. The next step was to move the U12 chip to the donor unit. And here comes the problem, when I connect it to the computer again it does nothing, it has no indication of starting the engine. I checked the welds and they were good. The next thing I did was to put back the U12 chip that came from the donor and I started again like at the beginning but with the click of dead.
The next step was to read the U12 chip from the bad PCB with an external programmer. I did several readings and they are all edentic, so he got it right. The next thing I did was put the donor PCB chip in and burn the original bad PCB bios to it. I did erase chip, write and verification. Everything OK.
The next step was to put the new PCB back on the disk and the exact same thing happens to it, it does practically nothing.
Conclusion: I think the bios of the damaged PCB must be corrupt. It's weird because looking at Hex format you have data.
Could a bios reconstruction be done with the backups I have of the original and the donor?
It is assumed that the adaptives could be removed from the original.
Thank you and greetings.
 Post subject: Re: Strange disk failure WD2500BEVT
PostPosted: September 1st, 2020, 8:35
The original ROM is not compatible with the donor PCB. Check the white labels on them.
P.S. Post the full model name, family name, etc. if you want to be helped .
PostPosted: September 1st, 2020, 10:26
Hi.
WD2500BEVT - WXF1A7013817
These are the complete data of the PCBs:
ORIGINAL PCB
SEGRAFIED ON THE PLATE PUTS: 2060-771672-004 REV A
ON THE LABEL IT SAYS: 2061-771672-F04 AA XT AB42 EFBH B 0001110 1 111
DONOR PCB
ON THE LABEL IT PUTS: 2061-771672-F04 AC XS AB60 5GKA 6 0005160 1165
PostPosted: September 1st, 2020, 11:34
Can you upload the file with the content of the original rom?
PostPosted: September 2nd, 2020, 4:33
Hi.
I attach the two rom. The ORIGINAL and the ROM of the DONOR
WD2500BEVT WXF1A7013817 BIOSCORRUPTA.zip [406.81 KiB]
Downloaded 1046 times
PostPosted: September 2nd, 2020, 11:53
The original rom code is corrupted. At least the header.
PostPosted: September 2nd, 2020, 13:51
Which cases could corrupt the header? Do you know length of header for Caviar WD400 and WD800 drives? (I believe the header are maybe the first 256 bytes. I am correct?)
Thank you in advance.
PostPosted: September 2nd, 2020, 14:11
The first 0x100 bytes are garbage. I have extracted the ROYL modules.
Analysing backup.rom.DONADOR.bin ...
Searching for LDSCs and verifying PCMBlocks ...
LDSC   LDSC    Att   PCMBlock          RAM         size      PCMBlk CS
Start  ID CS        Start -  End     address     RAM / ROM    Exp/Act
    0  5A 40   04     120 -  151C      18AC0     13FC  13FC    06   06   OK
   20  01 64   01    151D -  A5D1          0 c   B7E8  90B4    E5   E5   OK
   40  02 51   01    A5D2 -  FC2A       E464 c   7AB0  5658    24   24   OK
   60  03 26   01    FC2B - 103BB      16208 c    950   790    95   95   OK
   80  04 87   03   103BC - 1061C    4000080 c    36C   260    8C   8C   OK
   A0  05 82   03   1061D - 10E1D    4003DEC c    C04   800    97   97   OK
   C0  06 57   03   10E1E - 114FA   24000008 c    C1C   6DC    B7   B7   OK
   E0  07 FF   01   114FB - 2A79B   2401D000 c  20978 192A0    85   85   OK
  100  08 7B   01   2A79C - 32E50   24048800 c   AC50  86B4    19   19   OK
LDSC   = PM Loader Config String (32 bytes)
ID     = ID byte of LDSC (byte #0)
CS     = Checksum byte or word
Att    = Attributes
PCMBlk = Program Code Memory Block
Exp    = Expected checksum for PCMBLock
Act    = Actual checksum for PCMBLock
c      = compressed PCMBlock
size   = size of decompressed (in RAM) and compressed (in ROM) PCMBlock in bytes
ROYL directory module 0x000B found at 0x3FEE1
Active directory flag = 0x00
Identifying SA regions ...
Reg#  Reg size    Reg loc
0x00  0x00031C80  0x00000000
0x01  0x00031C80  0x00042600
0x02  0x00031C80  0x00084C00
0x03  0x00031C80  0x000C7200
Verifying ROYL modules ...
ID          Size (bytes)         Address    Checksum
dir   hdr    dir       hdr
000A  OK     0000003E  00000200   0003FFB2   00000000  OK
000B  OK     000000D1  00000200   0003FEE1   00000000  OK
0030  OK     00000400  OK         0003FAE1   00000000  OK
0047  OK     00000400  OK         0003F000   00000000  OK
000D  OK     0000008C  00000200   0003EF74   00000000  OK
004F  OK     00000400  OK         0003F400   00000000  OK
dir  -  Module ID/Size as reported in directory module (0x20B or 0x0B)
hdr  -  Module ID/Size as reported in module's header
N/A  -  Not Applicable
BAD  -  Module has invalid checksum. This may be due to non-existent module.
ROM modules saved to Flash_00\000Bmods and Flash_00\020Bmods
Active directory is 0x0B -- directory 0x20B not present
Analysing active 0x0A module ...
Head map checksum (Expected / Actual) = 0x0000 / 0x0000 - OK
Number of heads (physical / in use) = 4/4
Head map #1 = 0x0F / 0b00001111
Head map #2 = 0x00 / 0b00000000
DCM = | B | E S G S D 1 O
      : : : : : : : : : unknown
      : : : : : : : : top VCM
      : : : : : : : ACA
      : : : : : : bottom VCM
      : : : : : HSA
      : : : : media
      : : : preamp
      : : latch
      : base
      spindle motor
Analysing active 0x0D module ...
Firmware Version = 01.01A01
World Wide Name = 50014EE6AB446C20
Model Number = WDC WD6400BEVT-22A0RT0
Serial Number =
Analysing active 0x4F module ...
ROM version = 0014003R
Analysing active 0x47 module ...
Preamp values
0  083BC422
1  0931D315
2  0937B31D
3  0835C322
4  02200200
5  02200200
Microjogs
0  0B77
1  0AFD
2  0B21
3  0ACC
4  0A0A
5  0A0A
Head/Media DCM = GS
Analysing backup.rom.orginal.bin ...
  100  08 88   01   2A43C - 32B18   24048800 c   AC70  86DC    AC   AC   OK
Att    = Attributes
0x00  0x0001A333  0x00000000
0x01  0x0001A333  0x00037500
dir   hdr    dir       hdr
ROM modules saved to Flash_01\000Bmods and Flash_01\020Bmods
Number of heads (physical / in use) = 2/2
Head map #1 = 0x03 / 0b00000011
DCM = | B | N S G R H N V
      : : : : : : : ACA
      : : : : : HSA
      : : : : media
      : : : preamp
      : : latch
      : base
      spindle motor
World Wide Name = 50014EE25A35CE66
Model Number =
Serial Number =
ROM version = 0014003V
Preamp values
0  083BA329
1  0639C513
2  02200200
3  02200200
4  02200200
5  02200200
Microjogs
0  0C20
1  0B66
2  0A0A
3  0A0A
4  0A0A
5  0A0A
Head/Media DCM = GS
000Bmods.7z [784 Bytes]
Downloaded 941 times
PostPosted: September 2nd, 2020, 15:44
So he was definitely right that it is corrupt.
Att = Attributes
dir hdr dir hdr
: : : : : : : ACA
: : : : : HSA
: : : : media
: : : preamp
: : latch
: base
spindle motor
Serial Number =
Preamp values
0 083BC422
1 0931D315
2 0937B31D
3 0835C322
4 02200200
5 02200200
Microjogs
0 0B77
1 0AFD
2 0B21
3 0ACC
4 0A0A
5 0A0A
Head/Media DCM = GS
Att = Attributes
dir hdr dir hdr
: : : : : : : ACA
: : : : : HSA
: : : : media
: : : preamp
: : latch
: base
spindle motor
Model Number =
Serial Number =
Preamp values
0 083BA329
1 0639C513
2 02200200
3 02200200
4 02200200
5 02200200
Microjogs
0 0C20
1 0B66
2 0A0A
3 0A0A
4 0A0A
5 0A0A
Head/Media DCM = GS
Thank you very much for the modules. Is there a way to generate a new rom from those modules?
PostPosted: September 2nd, 2020, 18:03
The donor and patient have different ROM versions (according to mod 4F) -- 0014003V versus 0014003R. I'm not a DR pro, so others would need to tell you whether these are compatible.
Otherwise you could look for ROM version 0014003V and then use it to rebuild the code section.
PostPosted: September 2nd, 2020, 19:08
Your WDROMVx.exe utility for analyzing WD roms is impressive.
Does only works for new drives or ROYL types?
I had downloaded several versions of your utility to check some WD800BB and WD400BB drives (sabre53, sabre58, mammoth, etc.) and I can not get ahead of some lines in the analysis log file. For instance, I can not get the lines regarding firmware, WWN, serial number, etc.
Is there a method to obtain the serial number, WWN, etc inside ROM dumps for Sabre types, encoded in some type, ascii or hex? Or, maybe the question is, do Sabre roms have embedded in their roms that data?
PostPosted: September 2nd, 2020, 23:42
The WWN, serial number, etc are extracted from module 0Dh, but not all ROMs have this info.
The most recent WD architecture requires a different tool.
http://www.hddoracle.com/download/file.php?id=8795
http://www.hddoracle.com/viewtopic.php?f=3&t=2762
http://www.users.on.net/~fzabkar/temp/WD/WDnewROM.exe
http://www.users.on.net/~fzabkar/temp/WD/WDnewROM.bas
PostPosted: September 3rd, 2020, 2:49
Donor PCB is from Mariner 640GB with 4 heads , FW 143R
The original is Jamaica 250GB with 2 heads, FW 143V
By Hex Editor you should thansfer mod 0A, 0B, 30, 0D, 47, 4F from the original ROM to ROM of drive with FW 143V (Jamaica or Mariner)
PostPosted: September 3rd, 2020, 5:59
Hi.
I mean, would I have to insert the 6 modules that fzabkar sent me in the rom of the Mariner 640GB donor with 4 heads, FW 143R?
Or would I have to find another ROM with the FW 143V?
And in what hex position would I have to do it in the Hex Editor?
Thanks for the help, but I've never done this.
PostPosted: September 4th, 2020, 3:05
Maybe you should pay somebody that knows how to do it.
PostPosted: September 4th, 2020, 6:03
This hard drive is for the study of new knowledge. It is not from a client.
I have the MRT tool. Could the ROM be generated from it from the modules?
Thanks for the help.
PostPosted: September 4th, 2020, 11:06
:shock: :shock: Short answer, yes.
PostPosted: September 4th, 2020, 14:58
Looking at the hddoracle forum I have found how to insert the modules that fzabkar gave me. I have searched my firmware database and found a ROM from the same WDC family WD3200BPVT-22ZEST0-01.01A01. I have inserted the modules with the Hex HxD Editor.
Here I leave the modified rom so that fzabkar if it is very kind to analyze it with its utility and tell me if it is OK.
Thanks and regards
backup.rom.orginal.Rebuilding.bin.zip [202.77 KiB]
Downloaded 739 times
PostPosted: September 4th, 2020, 15:28
One question...what did you buy MRT for?
That model has a copy of the modules/ROM in SA....
PostPosted: September 4th, 2020, 18:26
Buy the MRT for data recovery.
As I already said at the beginning of this thread. The unit does not boot with the original bios. Therefore I do not have access to the SA.
The rom that I generated in the previous message did not work.
But anyway it is already solved.
I found another donor ROM in this forum.
WDC WD2500BEVT-22A23T0-01-01A01-0014001E-WD-WX11A40J2777
Which brings the firmware version 14001E, I added by Hex Editor the 6 modules and now it starts and works perfectly.
I found the usefulness of the friend fzabkar and these are the results of the reconstructed rom.
Analysing WDCWD2~1.BIN ...
    0  5A 40   04     120 -  151C      18AC0     13FC  13FC    C5   C5   OK
   20  01 80   01    151D -  A591          0 c   B784  9074    05   05   OK
   40  02 10   01    A592 -  FB9A       E464 c   7950  5608    EE   EE   OK
   60  03 9D   01    FB9B - 1032B      16208 c    958   790    B4   B4   OK
   80  04 F7   03   1032C - 1058C    4000080 c    36C   260    13   13   OK
   A0  05 F4   03   1058D - 10C1D    4003DEC c    BEC   690    CC   CC   OK
   C0  06 6E   03   10C1E - 111FA   24000008 c    B38   5DC    D0   D0   OK
   E0  07 ED   01   111FB - 29DAF   2401D000 c  20058 18BB4    2C   2C   OK
  100  08 51   01   29DB0 - 32324   24048800 c   AAA0  8574    C8   C8   OK
Att    = Attributes
dir   hdr    dir       hdr
0030  OK     00000400  OK         0003FAE1   00000001  BAD
      : : : : : : : ACA
      : : : : : HSA
      : : : : media
      : : : preamp
      : : latch
      : base
      spindle motor
Model Number =
Serial Number =
Preamp values
0  083BA329
1  0639C513
2  02200200
3  02200200
4  02200200
5  02200200
Microjogs
0  0C20
1  0B66
2  0A0A
3  0A0A
4  0A0A
5  0A0A
Head/Media DCM = GS
Thank you all for the help and knowledge.
Users browsing this forum: No registered users and 60 guests
