Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
 Post subject: help pcb WD 006-0b40829
PostPosted: September 1st, 2020, 13:59
Hi Guys, a customer brought me an 8 TB WD hard drive with the following pcb 006-0b40829. The motor does not spin, it is possible to hear a small noise as if it wants to start but it does not start, in MRT it remains in the BSY state, removing the pcb and leaving it alone it remains in the BSY state. According to the client, the problem arose after a small bump. Suggestions?, Thanks
 Post subject: Re: help pcb WD 006-0b40829
PostPosted: September 1st, 2020, 14:30
Stiction?
PostPosted: September 1st, 2020, 14:53
sounds like bad PCB
PostPosted: September 1st, 2020, 16:43
Spindel stuck, which can cause to motor-chip death additionally.
Angel Data Recovery
PostPosted: September 2nd, 2020, 4:21
Hi guys I think it's bad pcb, the motor it's free to spin, no lock, suggestion for repair ? any friend have a schematics ? Tks
PostPosted: September 2nd, 2020, 5:04
pcb swap with rom swap?
However, i would check the heads for bent suspensions first.
PostPosted: September 2nd, 2020, 7:11
Hi pepe, it's the first step for me, I have open the cover and have checked motor, if are locked and head. I haven0't this pcb and have thinked to repair
PostPosted: September 2nd, 2020, 10:40
Isn't it a Helium drive?
PostPosted: September 2nd, 2020, 14:11
Not all 8 TB are helium filled.
Example:
WD80EFAX-68LHPN0 - helium filled model
WD80EFAX-68KNBN0 - air filled model
My firmware database:
PostPosted: September 2nd, 2020, 14:18
If you can provide a better photo (with a CCD scanner ?) I could identify the voltage test points. That said, I suspect that the motor controller may be faulty.
PostPosted: September 3rd, 2020, 12:34
Example:
And what PCB number is on the air-filled drive?
PostPosted: September 3rd, 2020, 14:39
Example:
It would appear that the OP's PCB is used in the WD80EZAZ-11TDBA0, which is a HGST helium model. I don't know whether the same PCB is used in air models. If not, and if the OP has an air drive, then could it be that the customer has replaced the PCB?
Repairing pcb 006-0B40829 from hdd WD80EZAZ-11TDBA0:
https://www.youtube.com/watch?v=qCngNEhfF24
https://www.ebay.co.uk/itm/WD80EZAZ-11TDBA0-P-N-2W10207-Thailand-Western-Digital-8TB-/174065406127
Model number: WD80EZAZ-11TDBA0
Part number: 2W10207
006-0B40829 on the PCB
https://www.smartmontools.org/ticket/959
I recently got a few WD80EZAZ-11TDBA0's. These appear to be WD White label "Ultrastar He10-8 (US7SAL080)", smartctl seems to detect all except one property: "22 Unknown_Attribute" If I am not mistaken that should be the Helium sensor.
The date code on the PCB is 2419, week 24 of 2019.
PostPosted: September 3rd, 2020, 19:43
That's why I'm still waiting for my answer about the drive HDA type :)
PostPosted: October 15th, 2020, 6:19
Update, hi friends the i have take same pcb from 10 TB HDD and have swapped rom, now the disk spin normally but don't work, i not heard noise from head positioning and i think the pcb are locked. I have connected the unit to original usb drive (it's a mybook drive) but nothing. Suggestion ? TKS
PostPosted: October 15th, 2020, 10:51
Since you already opened the drive, you can throw it to garbage now.
PostPosted: October 16th, 2020, 3:38
from what you write it is clear that you have not understood anything!
PostPosted: October 16th, 2020, 12:24
clearly
PostPosted: October 16th, 2020, 12:31
ok, I'll make it easy for you
The drive does not unpark heads because either heads are bad or because there is no Helium inside the drive anymore.
Since you opened the drive I would think it's because of the latter.
Basically you killed the drive for no reason. You can tell that to your client.
PostPosted: October 16th, 2020, 16:14
PCB 004-0B36131
PostPosted: October 16th, 2020, 17:06
Check smart under Victoria
https://hdd.by/victoria/
If smart is detected then try to read hex sectors in r-studio (drive must be connected in the original enclosure). If you see only E5 pattern then you have same issue as me.
I had a similar case and i came to the conclusion that translators are damaged.
https://forum.hddguru.com/viewtopic.php ... 13#p284513
At the moment there is any solution yet. :?
Users browsing this forum: No registered users and 43 guests
