 Post subject: How do I obtain or reset Samsung hdd smart data
PostPosted: October 21st, 2020, 9:26
My Samsung hdd cable has been damaged, causing a "Communication Problem Between Disk and Host" error. Change the cable and fix the problem. Is it possible to reduce this value to zero only from Smart data? If not, how do I clean Samsung hdd's smart values?
 Post subject: Re: How do I obtain or reset Samsung hdd smart data
PostPosted: October 23rd, 2020, 21:01
Banned User
it need a professional tool , you can't just clear smart, find any professional pc repair or data recovery. they can do that.
Optimal casual Dating
PostPosted: October 24th, 2020, 3:47
You need a specific tool, PC3000 or MRT
PostPosted: October 24th, 2020, 5:05
Not true.
PostPosted: October 25th, 2020, 16:08
I have seen on the youtube that the smart data of the seagate hdd can be clear with the usb ttl adapter. If I buy a usb ttl adapter, can't i interfere with samsung's smart data? Can't I change or delete Samsung's smart data if I buy a usb ttl adapter?
