 Post subject: ST1000LM035-1RK172
PostPosted: June 16th, 2022, 13:21
Need someone to edit this sysfile 93 in PC3K to disable all background activities and post it back.
Thanks in advance.
Volume_3 FID_93.rar [867 Bytes]
Downloaded 296 times
 Post subject: Re: ST1000LM035-1RK172
PostPosted: June 16th, 2022, 13:47
Why can't you just enter the appropriate F command in terminal?
http://www.hddoracle.com/viewtopic.php?f=59&t=1842&start=80#p14731
PostPosted: June 16th, 2022, 14:15
Already did.
And the drive now report 0 capacity.
PostPosted: June 16th, 2022, 14:57
Translator not loaded
PostPosted: June 16th, 2022, 16:16
Now ID correctly with full capacity but aborted command ( no UA access )
Any suggestions?
PostPosted: June 18th, 2022, 9:48
what do you get in status and error registers? what's the result of '.' ?
PostPosted: July 22nd, 2022, 4:12
Can someone explain what background activity it is and why to disable it ?
Can it be useful for me ?
I have the same drive in an external slim ... it has only 71 startups since 2018
Users browsing this forum: Majestic-12 [Bot] and 69 guests
