 Post subject: SA damaged report from pro
PostPosted: October 13th, 2020, 12:27
HDD Seagate
System ID and capacity shows in Bios and Disk management(unallocated)
My question is it true SA Damaged ?
I tried in terminal
Init Smart fail error with LED 000000CC error in both Commands Smart Clear and regenerating Translator
 Post subject: Re: SA damaged report from pro
PostPosted: October 13th, 2020, 17:26
If the drive is visible with both model and capacity in bios, clone the drive with a non os system...like ddrescue or similar.
http://www.rescue-it.se
PostPosted: October 17th, 2020, 3:23
After Back from Pro Not detecting in Bios
still Have same error
PostPosted: October 17th, 2020, 11:07
[quote="prasadsv"]After Back from Pro Not detecting in Bios
still Have same error[/quote
do you have any pro tools ? it would be easier.
else only option is as given by "mr_spokk"(if you do not want to send it to proper Dr place)
Users browsing this forum: No registered users and 55 guests
