 Post subject: Toshiba MQ01ABF32
PostPosted: October 20th, 2020, 14:20
Hello
i have an hdd toshiba who is come from a Canon MFP.
I want to format them to be use on Windows but when i see the hdd on windows and try to initialize it i have this return:
acces refused .
So i can t do anything whit this hdd.
I found the firmware : AM001A and this S.M.A.R.T., APM, NCQ.
i don t know how to repair it
Can you help me
Thanks a lot
 Post subject: Re: Toshiba MQ01ABF32
PostPosted: October 21st, 2020, 3:27
it might have a password, try installing minitool partition wizard and try to delete the partition.
PostPosted: October 21st, 2020, 9:45
If the drive protected with ATA password it cannot accept any command ( reading or writing ) until it unlocked.
PostPosted: October 21st, 2020, 12:04
Ok so without this password impossible to format it.
i will try to find it
PostPosted: October 22nd, 2020, 3:57
You have installed minitool partition wizard ? post a screen
PostPosted: October 23rd, 2020, 16:25
hello
i see the hdd but it take a long time du analyse
i have a scrennshot with victoria
PostPosted: October 24th, 2020, 4:32
psytgc wrote:
hello
https://www.youtube.com/watch?v=4-bU945-k1I
PostPosted: October 24th, 2020, 5:16
It takes less than a minute to unlock a Toshiba 2.5" drive.... if you know some VSC commands.
:D :D :D
PostPosted: October 24th, 2020, 8:59
So can you help me?
PostPosted: October 24th, 2020, 9:41
ok
i finf this
Device Configuration Restore
COMMAND CODE 1 0 1 1 0 0 0 1 REGISTER
REGISTER SETTING NORMAL COMPLETION
DR DRIVE No. no change
CY na na
HD na na
SN na na
SC na na
FT C0h na
LBA na na
The DEVICE CONFIGURATION RESTORE command disables any setting previously made by a DEVICE
CONFIGURATION SET command and returns the content of the IDENTIFY DEVICE or IDENTIFY PACKET
DEVICE command response to the original settings as indicated by the data returned from the execution of a
DEVICE CONFIGURATION IDENTIFY command.
but how ti use it.
there no data on this hdd, and i have 5 or 6 hdd like this so that why i want to unlock them.
PostPosted: October 25th, 2020, 3:20
psytgc wrote:
So can you help me?
Remotely? No.
Spildit used to offer such a service on e-bay. Check it out.
